Front load W & D stack attack, What tool ?
6 replies to this topic
#1 curjones
curjones
    Senpai
  • PipPipPipPip
  • 531 posts
  • Flavorite Brew:diet coke
Posted 22 January 2014 - 12:12 PM
When I was in Best Buy in Florida I noticed they were displaying front load full size in the stacked position.  That may be great for the customer and space, but not good for the Lone ranger repair man.  We will have to have help or a tool.
How can we attack the stack if we are a one man army, army of one.
What tools are availabe.  Seen some for ranges will they work.  What is your method.  I have not yet been attacked by a stack.
#2 zogman
zogman
  • 10 posts
  • Flavorite Brew:coke or nestle's quick
Posted 22 January 2014 - 08:54 PM
I carry a oven dolly . I just raise the wood platform up to the height of the bottom of the dryer and release the connectors between the washer and dryer . I then slide the dryer off the top of the washer and onto my dolly and roll it out of the way.
Hope this helps
#3 -Mike-
-Mike-
    Kohai
  • 338 posts
  • Flavorite Brew:diet Pepsi
Posted 22 January 2014 - 09:19 PM
I have an oven dolly I made to work with unstacking the dryers. Its basically a table that I can set to any height with casters on it. I'll raise it up to where it would slide over the washer, then lean the dryer back and slip the table under the dryer. Then lean the dryer back forward and its sitting on the table able to be wheeled around out of the way.
#4 curjones
curjones
    Senpai
  • PipPipPipPip
  • 531 posts
Posted 23 January 2014 - 10:53 AM
I saw a oven dolly, here on the sight. Do you have to have an assistant to put it on the dolly. I sort of see that you could lay it down strap it on the dolley and then lift it, or lowerer it and remove it without help. I also see on the service call an additional fee to stack and unstack dryers off washers. They are hard to get around in a confined space that most are in already. I actually think about having a service trailer big enough to just take them out and work on them in when the problem may require a bunch of dissassembly, and posible water leak or floor damage.
I was searching the net yestersday and found the POWER Mate hand truck, stair climber, they are probally very expensive. They would be great for me to load units I sell into the back of customers trucks, especially refrigerators. I dont have a load ramp or dock. Will put up a link later. Someone may have one already.
#5 sh2sh2
sh2sh2
    Senpai
  • Master Appliantologist
  • PipPipPipPip
  • 755 posts
  • Flavorite Brew:yeunling
Posted 31 January 2014 - 07:48 PM
the only problem with a dolly is i see alot of stacked units in a space that is too small for a dolly
#6 curjones
curjones
    Senpai
  • PipPipPipPip
  • 531 posts
Posted 01 February 2014 - 01:10 AM
When you use the dolly, do you have help rasing them up or can you do it by yourself by laying the dolly and unit down.  Would like to see some pictures of your made /modified dolly.
#7 Thirstytech
Thirstytech
    Kohai
  • 448 posts
  • Flavorite Brew:Greenbush Starchicken Shotgun
Posted 01 February 2014 - 01:19 PM
I use one of these, never had a problem in tight spaces.
http://www.alldolly....-down-standard/
