Whats your favorite fancy tester
Tester.
56 replies to this topic
#41 BryanS
BryanS
  • 1,395 posts
Posted 25 October 2014 - 09:50 PM
Thanks. That's what I thought because I really couldn't find any different whirlpool tester anyway. My shop is transitioning me into working on dryers now. Just happened to check ebay and found those for a good price so I figured why not :)
#42 Applianceman97
Applianceman97
    Baby Sensei
  • 2,203 posts
Posted 26 October 2014 - 02:53 AM
I use that Ge diagnostic tool all the time. It's worth the money. I actually got my display out of an old refrigerator. Worth every penny
#43 BryanS
BryanS
  • 1,395 posts
Posted 26 October 2014 - 07:26 AM
Sounds good. It's main use is for the GE with the manual knobs right? Do you usually hook into the connector under the grill or what? I really never knew how to run diagnostics on a GE until I was browsing through some GE troubleshooting files on here and thought it might come in handy for testing defrost. Instead of pulling the fridge out and jumping the heater like I usually to help defrost or do my ohm checks. At least know I know how to run diagnostics on the ones already equipped with the display. I wanted to be able to run a diagnostic on a GE SxS dual evap inverter compressor fridge the other day because I wasn't convinced it was running full speed. The freezer temp controls were on the door though, and was a lot different then I'd ever seen. I'd be curious to know if I plugged up the diagnostic tool if it would work in place of the door display. The board looked like the basic one used for the older dual evap units. Either way, I ended up installing a dye drier thinking it was a leak issue, and they haven't called me back for it not cooling yet.. Going back this week to look for dye, but I find it doubtful I'll find anything. It seemed to still have a decent amount of refrigerant still in it.
Ideally it would be nice to get a display off of a junked GE fridge, but most of those tthat come in are easily fixed and resold.
Edited by BryanS, 26 October 2014 - 07:25 AM.
#44 DurhamAppliance
    Sho' Nuff Chozin
  • 5,256 posts
Posted 26 October 2014 - 08:24 AM
it will work on most all GE profiles and arcticas. If the fridge has only a 4 button control (you need five buttons on the control to enter diagnostics), or has a dispenser control (they have very limited on board diagnostics) , you must plug the diagnostic panel into the j4 connector on the board. Doing this means you have removed the connction to the fridge's control panel, elimnating interefence. For models with dials, you can connect it to the connector at the hinge.
www.DurhamApplianceThrift.com
#45 BryanS
BryanS
  • 1,395 posts
Posted 26 October 2014 - 08:42 AM
Thanks. Yea, the fridge I was on had the dispenser buttons. I want to say it had like 6 buttons. It didn't have the regular up and down temp setting. It had a temp setting them you switched from fridge to freezer to set your 0 and 37 temps.
#46 DurhamAppliance
    Sho' Nuff Chozin
  • 5,256 posts
Posted 26 October 2014 - 08:59 AM
Yeah, you have to plug it into the board. The 4 button controls I mentioned look exactly like the test panel and is found in the ff section. Many times I have found manuals for these fridges explain how to get into diagnostic mode only to find there isn't a fifth button to activate the diagnostics. On dispenser models like the one you are working on, the manuals correctly explain how to get into diagnostic mode but say it is very limited and then advises using the test panel instead.
#47 BryanS
BryanS
  • 1,395 posts
Posted 26 October 2014 - 10:14 AM
Sounds good. I'm going to talk to my boss on Monday to see if I can go ahead and order the parts if I buy them. I'd rather the tester be mine anyway.
#48 MicaBay
MicaBay
    Master Roaster
  • PipPipPipPip
  • 871 posts
  • Flavorite Brew:Drifter Pale Ale
Posted 27 October 2014 - 10:36 PM
Just looked up the WP 240volt outlet tester. It is about $40 each for us. Not to shabby.
#49 BryanS
BryanS
  • 1,395 posts
Posted 28 October 2014 - 05:21 AM
Yea, if you get it from a parts supplier. I think Marcone had it for $84.
#50 BryanS
BryanS
  • 1,395 posts
Posted 31 October 2014 - 05:10 PM
Sooo did anyone else's outlet tester come with a lanyard that attaches both testers together? It just looks like a lanyard to me, and I want them seperated.
#51 DurhamAppliance
    Sho' Nuff Chozin
  • 5,256 posts
Posted 01 November 2014 - 01:50 AM
No, mine came separated.
#52 BryanS
BryanS
  • 1,395 posts
Posted 01 November 2014 - 06:26 AM
Interesting. I may just cut it off. I don't think it has anything to do with the operation of the testers. It's almost like they did it so could keep them together and not lose one of the other. I can see what looks like a screw under the overlay that holds the landyard/cable on.
#53 Stevenr4522
Stevenr4522
  • 18 posts
  • Flavorite Brew:coffee
Posted 27 December 2014 - 08:59 AM
My favorite tester is between my ears. My eyeball look for stuff......my nose sniff for stuff......my ears listen for clinks, squeals and who's never heard this " my husband's a master electrician and he said you need to order the whatchamacallit........". Seriously I have tons of meters and testers. It's like an obsession......looking for that magical tester to save time.
#54 DurhamAppliance
    Sho' Nuff Chozin
  • 5,256 posts
Posted 27 December 2014 - 10:52 AM
Unfortunately, the engineers who designed the latest appliances did not use that "which is (supposedly) between their ears" thus many times using "what is between your ears" won't help. Also with the new electronics, many times you cannot see, smell or hear anything wrong other than an obvious symptom
#55 Stevenr4522
Stevenr4522
  • 18 posts
Posted 27 December 2014 - 11:48 AM
Yes Grand Master you are correct. My levity may have been taken the wrong way. My favorite tester is my Fieldpiece 36 which allows me to check current, resistance, capacitance, volts and temps. I have a collection of various amprobes , Fluke meters and IR temp devices, but my Fieldpiece is my favorite. I've used a logic probe on occasion to test sensor circuits.
#56 santacruzappliance
santacruzappliance
    Ikkō-ikki
  • Appliantologist
  • 44 posts
  • Flavorite Brew:Sculpin IPA
Posted 12 January 2015 - 12:21 AM
Does anybody have a link to the whirlpool 240V outlet tester? To purchase one that is.
#57 Applianceman97
Applianceman97
    Baby Sensei
  • 2,203 posts
Posted 15 January 2015 - 12:28 AM
Part number: ap3841213
Edited by Applianceman97, 15 January 2015 - 12:34 AM.
