jena
Fisher Paykel GWL11 issues
3 posts in this topic
I am not sure I can repair this myself, but I am willing to try before calling in the repairman.
Washer drains (but not all the way) after the first fill in the wash. Then it stops and you get beeps and flashing lights( lights flashing= whatever wash time you set it to when you started, as well as the Hot and Cold temp lights).
When you put the machine into diagnostic mode you get a fault code of 6 (4+2).
I think it might be a diverter issue, since I think after the first wash light goes off it should recirculate the water (right?) instead of draining it.
Open the control panel and get the tech sheet inside there.  It'll decode the code for you and point you to the problem.  Here's the service manual for this washer:  http://appliantology.org/files/file/241-fisherpaykel-gwl11-washer/
You'll need to upgrade your membership to download it:  http://apprentice.appliantology.org/
Diveter and pump has been a problem
