  • Announcements
wandering_burr
GE jtp27woa1ww - Flash, pop, trip
9 posts in this topic
Double in wall oven. Two weeks ago I had an F9 error code which I reset and hasn't re-appeared. The error code has to do with the Door Lock circuit which didn't seem too problematic. Last night while running the top oven at 425 and the lower at 200 for a dinner party we had a bright flash with a 'pop' noise which tripped the breaker. The acrid smell of electronics filled the kitchen.
Last night we left things dark and I investigated this morning. Upon reseting the breaker the oven lit up and even heats (at least for the 30 seconds I had it on for my test).
A little google bird claims that it might be a clogged fan intake that requires me to pull the oven out of the wall to clean. But that flash and smell makes me think that something electronic is burned out somewhere.
What would you recommend I do?
Hmm, I'm sure there should be an edit post button here somwhere but I don't see it. I wanted to add that the ovens are about 17 years old with moderate use. The main control board was replaced about six years ago.
Grasshoppers may not edit their posts; that is one of the many perks and privileges reserved for Apprentices and Appliantologists:  http://apprentice.appliantology.org/
Usually, things that go pop-flash in the night are visible. You may want to disassemble the control panel and have a look at the control board and the door latch assembly. Also check the elements to make sure they aren't visibly burnt.
 The service manual would be a great asset to have for this repair Odyssey.  Here it is:  http://appliantology.org/files/file/422-ge-wall-ovens-v1-v2-series-31-20234/
 You will need to upgrade your membership to download it.
I opened 'er up and there is no evidence of scorch or other visible clues of a problem. The Oven Control Board smells like burnt plastic but there is no visible damage on the exterior except in the upper left corner of the display there is a scorch mark. I don't know if that is new or old. As I wrote the control board starts up the oven and seems to function fine.
While I had it open I visually inspected the rear fan intake and it looks fine, no blockage. I have noticed that the fan doesn't seem to turn on unless the ovens have been on for quite some time. Can you tell me at what temp it is suppsed to activate at? I wonder if that sensor is faulty and the Control Board has been cooked to the point it has faults.
The control board also has lots of items that are not visible without further dissembly--but that task appears to be possibly a one way trip with brittle plastic tabs to pry open.
The front plastic fascia of the Control Panel generally will not show the scorching that may or may not be there. The scorching, if present, would typically be on the back of the PCB board where the solder joints are. You would need to unclip and unfold the PCB in order to fully examine it. If the oven is operating within design parameters, then the wisdom of doing this could be dubious or at least more trouble than it's worth.
Hmmm, free light show last night while cooking. Today it appears to be working as designed again.
Should I go back to using the oven and see what happens next? Or is the free light show likely a precursor to a larger electrical problem that needs professional inspection?  I wouldn't mind spending the $200 on a new board if it is likely the culprit--but if the board fried because of another piece of the oven that could be wasted money....
I am understanding the concept of 'aggro dollars' better today than i did yesterday.
Ichiban Law of Appliance Repair: Don't "fix" what ain't broke!
Use the range as is see what happens. You're not gonna make it "more broke."
Back again a year later. The oven was used several times a week w/o any issue. Just before the holidays I ran the Self Clean cycle and had the pop and trip of the breaker again. Then this weekend I ran a 450 degree cook and now the breaker trips immediately on reset. I pulled the top panel off and this time there is obvious visible damage to the wiring. Where the wiring comes out of the metal conduit from the back of the unit and joins into a connector things are a bit melty. is this something I attack on my own, call in someone, or shop for a replacement oven?
Looks like one of the images I uploaded I sent the wrong size. The large image is of the connector from the Conduit Wire Harness to the oven. What would cause something like that? Probably the more pertinent question is the cause going to be relatively easy for myself or a repair person to track down? If this is more than around $600 or a day or two of my time/effort I will probably just upgrade to something more contemporary.
Just a bad connection at your Molex plug. After cutting power to unit, just cut plug out of harness. Cut back wires far enough that they are clean. Strip and wire nut. White to white, red to red, black to black. You get the idea. 5-10 min job. Make sure to use quality wire nuts and get them tight. It'll be fine for the test of the ovens life
