Kenmore Refrigerator 106.56232400 frosting
5 replies to this topic
#1 roberto
roberto
    Yamabushi
  • 81 posts
  • Flavorite Brew:Stella Artois
Posted 29 January 2014 - 11:45 AM
We have encountered a difficult Kenmore Refrigerator 106.56232400 that continues to frost up in the upper third of the freezer section leading to the vents closing off due to frost/ice, resulting in a warm refrigerator side. At first glance we suspected warm air entering the freezer, but can find no source for warm air. The flap in the ice chute is working and sealing properly. The door seals look and test good. The evaporator has a good pattern, the thermistor and defrost heater are good and it appears to be defrosting, but the drain was clogged with ice that melted periodically on the kitchen floor. We thought about air enter from the drain tube. The ice maker is not connect to a water supply ( no water drips ) but it is totally covered in frost. We learned after being called back that other technicians have tried to solve this machine's issues.  Your thoughts, ideas or guidance will be appreciated.
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 5,901 posts
Posted 29 January 2014 - 01:11 PM
Here are some possibilities
1 Check for air intrusion from the water fill tube.. This usually applies to non-indoor ice models where the tube is not connected, unplugged or missing and there is no tape covering the hole.
if your icemaker water feed tube line is disconnected from the valve, then this could be your problem.
2)something i discovererd recently and blogged about it. Although it was a ge, symptoms were similar. http://appliantology...mittent-fridge/
in essence, I did a lot of testing and was about to give up only to find the ice chute door was hanging open but occasionally. It looked good upon inspection but only discovered the problem after open and closing it several times. From now on I test that door several times, open it by hand as well and check to see if it closes each time. I guess I will call that an "ice chute door reversing test." Easy to miss and I was lucky again.
3) disconnect the icemaker completely, if its mold heater is staying on, it may be causing your problem... ive only this once but had similar symptoms.
Edited by DurhamAppliance, 29 January 2014 - 03:26 PM.
www.DurhamApplianceThrift.com
#3 PDuff
PDuff
  • 2,112 posts
Posted 29 January 2014 - 03:39 PM
Actually, this is a pretty common phenomenon on the Whirlpool made SxS IDI refrigerator, regardless of age.
Inspect the liner lip where it meets the cabinet edge at the front of both fresh food and freezer compartments.  Gaps can form between the liner and cabinet that can allow warm air intrusion that over time, will cause the air return located in the mullion just above the crisper drawers to ice up.  This stops the air circulation causing the diffuser and most of the freezer to frost up like a winter wonderland.  Eventually the defrost drain ices up, which just adds to the fun.
Whirlpool's recommended repair is to replace the spacers located at the upper corners of the cabinet and to apply food grade silicone sealant to the entire perimeter of the front liner lip of both compartments to seal any gaps, seen and unseen.  Usually just sealing the liner lips takes care of the problem.
Use care when deicing the air return.  The Styrofoam duct is fragile and once damaged or collapsed, no further repair is possible.  Use a steamer or hot water to clear.
#4 DurhamAppliance
    Sho' Nuff Chozin
  • 5,901 posts
Posted 29 January 2014 - 06:11 PM
i have never seen this.... is there a bulletin on this issue?
#5 lesguns
lesguns
  • Chief Appliantologist
  • 19 posts
Posted 30 January 2014 - 01:04 AM
service pointer 8178611-----2006
#6 DurhamAppliance
    Sho' Nuff Chozin
  • 5,901 posts
Posted 30 January 2014 - 06:21 AM
cool.... it's in the dl section ... here ya go, roberto
http://appliantology...tions-and-tips/
it includes a number of things to check, including changing bi-metal (it may test ok but cutting in early or intermittent) and verifying location of bi-metal, replacing drain tube with p-trap.
Although not listed in the bulletin probably because WP isn't taking into consideration user error or tech incompetence, verify correct air flow direction. An incorrect fan blade /motor can cause these symptoms as well.
Edited by DurhamAppliance, 30 January 2014 - 06:53 AM.
