Malumake
Kitchenaid KGSI901 Gas Oven/Range:: Oven not heating correctly
6 posts in this topic
Aloha all,
My oven stopped heating correctly in the middle of baking.  The gas range works fine.  The electrical heating coil for broiling is working.  The thermometer seems to be still reading temp.  I hear the clicks for the ignitors, but don't see any sparks or hear/smell any gas in the oven. On power down (unplug) and then power on (plugin) I receive the following::
KITCHEN-AID
            05
      AM71 UI73 EEKGO-092
Mahalo in advance!
Full Model Number ::
KGSI901PBS01
Narrowed it down to ERC, Spark Module, or gas valve.  Pulled ERC and Spark Module, and checked for bulging caps, checked continuity on various transisitors, found no faults.  Did the same for the ERC, same results.  Got under the oven and tested the solenoids, one was fine the other was not.  New gas valve ordered.
Some terminology so we can communicate and understand each other:
Range: an appliance that has both an oven and cooktop
Oven: the compartment with a door that heats up for bake or broil operations
Cooktop: the surface burners
Now, what part of your range is malfunctioning?
The oven of my range quite heating in the middle of baking.  The gas cooktop works fine.  I figured out the problem and should have the new gas valve in a few days.
Just received part and installed.  Works great!
