Laz
GE GFC300V Garbage Disposal Leaking
6 posts in this topic
Hello there, I have a simple quick question about a garbage disposal unit. Near the bottom of the unit there is the pipe that connects to the drain, that's obvious. However, above that there is a hose connected with a hose clamp that is approximately two feet long and is capped at the other end. It goes nowhere and connects to nothing. Are disposals supposed to have a drain hose (other than the main) or a vent or something? This was here when I bought the house and it's now leaking where the hose is clamped onto the side of the disposal. I'm just wondering if that was the proper way to install this or if that hose should go somewhere and actually serve a function (which is seems like it should). Does anyone have an opinion? I'd appreciate any advice you can offer. Thank you!
I don't know much about garbage disposals but it sounds like it is probably some sort of vent. Maybe another one of the wise ones on here can give a better answer, so both of us may learn something.
I was just thinking do you have a dishwasher? I think some dishwasher drain lines may get hooked into the disposal. I'm just thinking out loud here though.
AhA! You make a good point. There was a dishwasher here at one time but it was removed. Maybe that line came from the dishwasher. Thank you!
No problem. I'm trying to learn about these other appliances myself lol. I'm a refrigeration guy. I just started thumbing through this appliance book I have and I didn't see anything about a vent. I thought I read something before about dishwasher drains being hooked up to them, and sure enough I found it in here. Hopefully, that's all it was.
There used to be a DW hooked to it. Take a wine bottle cork and put a plug in that disposal.
2 people like this
Ah, ok, put a cork in it.
