  • Announcements
bigr
ge washer whre555ok2ww
3 posts in this topic
ok I found mode shifter bad coil is open and have 4 blinks on motor lite  I see its a shaft with shifter . do u pull out transmission or can turn tub upside down    do u need to remove basket any help will help   thanks
  There is no transmission. Must remove inner tub. Pull outer tub and assembly out and flip over for replacement of mode shifter. It is recommended by GE that motor/inverter be replaced as well because blown fuse in shifter coil assembly is caused by bad programming on inverter board. Problem occurs when lid is opened at certain time during the cycle. If you load washer as instructed and leave it, your ok, but if you go back and open lid, that's when problem can occur.
Eric
Edited by fairbank56
