Darryl Fleming
Jenn Air JDB1100AWS Heavy Wash blinking in diagnostic
4 posts in this topic
I discovered how to put the dishwasher into diagnostic mode and what it is giving me is a blinking HEAVY WASH light. I cannot find what this code indicates.
What the dishwasher is doing is filling up then begins to pump a few seconds then stops then pumps then stops then it shuts down completely with all the display lights going off. Can someone give me a clue what is happening?
Thermistor - failure - Heavy Wash LED
During the field test mode it's normal for the Heavy Wash led to blink.  The field test checks components in the following order:
Seconds                        Function/Load
106                                 Water Valve
5                                      Thermistor/Turbidity Sensor check
120                                 Wash Motor/Dispenser Wax Motor
180                                 Wash Motor/Heater
120                                  Drain Pump
4                                     Water Valve
Does the unit drain properly when cycle is cancelled?  How does your main power connection look?
