  • Announcements
dunnright00
GE refrigerator water dispenser stopped working
16 posts in this topic
Hi all!
GE Side by Side, model #PFCS1RKZA SS, water dispenser just stopped.
Still makes ice, light goes on when I trigger the arm.
I don't remember hearing any noises before, but if I put my ear to the door when I press the trigger I hear nothing.
Tried the hair dryer on the front & back of the door in case the line was frozen and that did nothing.
Any other ideas?
Well first off you need to make sure the line being frozen in tbe door is your problem. Take the toekick off the bottom front. Unhook the connector by pushing in the ring as you pull out on the tube. Lay the tube on a towel with the door closed and activate the water to check if you have water to the door. If you have water to the door then it is frozen in the line. The blow dryer will work but sometimes it can take quite awhile and you have to switch back and forth quite so you don't melt any plastic. A Zoom spout can be used. It is basically a can of oil with a thin spout. Obviously, you would need to dump the oil and clean it well. There is a dispenser heater kit available but it works on metal liners only. You will need to determine what type of liner you have inside. Part#wr49x10173.
http://www.amazon.com/gp/aw/d/B000HACY3Y
http://www.repairclinic.com/PartDetail/Heating-Element/WR49X10173/1381601
The zoom bottle can be filled with hot water and the tube will fit up inside the water line of the dispenser to thaw it.
Edited by BryanS
Thanks for the quick reply!
I've seen before the method to take off the toe kick and unhook the connector, but when I took off the toe kick I didn't see a connector down there.
Just an electrical connector. I'll take a picture when I get home tonight, but I was looking and looking and couldn't find anything...
O wait. This is a bottom freezer. I should have looked at a parts breakdown first. Ignore what i just said. You might have to pull your drawers out and thaw the tanks out behind them. I think this had some kind of a service flash to replace the foam in the damper. The damper is also located behind those crisper drawers in tbe middle floor of the fridge section. You may have air leaking around the seal causing those to freeze. Sometimes I just I put a permagum or rtv around the seal of the damper. It's best to remove that assembly and seal the foam directly. I would try that first because I really didn't see much of a difference except in the gasket material on the new foam block.
Edited by BryanS
Are you talking about the crisper drawers, or the freezer drawer?
Is there a connector somewhere that I can test if there is water flowing, or is this further back so it wouldn't work like that?
first check to see if your valve is working. Disconnect the large line from the water inlet valve... press the water dispenser button to see if water comes out.
crisper drawers. I think there is a connector on one of the tanks. You may have to check at the water valve to be sure if water is coming through. I'm not sure of the exact position of the connector so I can't say if a frozen tank will still interfere with checking it. More often than not it has been a frozen tank and usually the right side tank.
Look for broken wires in the lower door hinge
Ok, I will check this tonight. Thanks!
Do you know where the water inlet valve is located on this model? I can't seem to find it...
It's in the compressor compartment on the left side. You will have to pull the fridge out access it
Ok, so this is what I see behind the crisper drawers. I assume the blue connectors will come off so I can check here, but I don't se a way to get it disconnected.
Short of yanking it off, what d I do here?
Those are John Guest fittings.
If you are able to get it to stick, I have been known to insulate those tanks with foam after thawing them as well. I used to use the extra foam that came with 819043 heat probe kit. I wonder if you could use that thin sticky pipe insulation they sell at Lowes for copper pipe. It doesn't necessarily fix exactly what is causing them from freezing, but I've had a few that I insulated because nothing else seemed to stop the freezing.
Ok, I was able to disconnect the John Guest fittings, closed the door and pressed the water cradle.
Nothing came out..  :confused:
Nothing will come out if the tanks are frozen. Did you verify the water actually comes out of the water valve in the back? You will probably need to remove that shelf above them and remove the screws that hold the tanks on so you can hit both sides with a blow dryer or heat gun. Hopefully you have a water filter in because otherwise nothing will get through either. I had a customer take theirs out and threw it away and no one told me. I replaced the leaking water valve and couldn't figure out for the life of me why I had no water still.
If ice is being made , there is no issue with the filter or filter assembly but we will check it out anywqy
With these fridges, it's easier to track down the problem by starting at the valve.
1) turn water off
2) disconnect water line feeding into the valve, it is probably coming from the water filter assembly. As stated earlier, if ice i being made, you shouldn't have a problem with the filter assembly but we are doing this sequentially. Once the line is detached, turn spigot on to see if water comes out of the line. If it does, it confirms the filter and head assembly is good. Reattach water line to valve. Disconnect the larger line connected to the valve. It is a John Guest fitting. Make sure water is on then press dispenser, If water comes out, then you have a frozen line somewhere. If not, you either have a bad valve or an electrical problem.
If water does not come out there are several ways to determine if the problem is electical or the valve itself.
Remove the electrical connection on the water dispenser side of the valve (blue colored chamber). Use a meter to determine if 120vac is found when the dispenser is activated. If you get 120vac, replace valve. If not, check wiring at door. You can also introduce 120v to the valve using a lamp cord, etc and connect it to the valve. The third method is to switch the red and blue electrical connectors but they are different sizes on this particular valve.
Edited by DurhamAppliance
