GE washer WJSR2080V1WW
BryanS
http://appliantology.org/files/file/235-ge-washers-with-electromechanical-controls-and-mode-shifter-assembly-service-manual/
wjsr2080v1ww
GE 8 cycle 2 speed heavy duty.
Would this be the manual be the same as what the washer I posted? The first four letters match one of the models listed. My sisters neighbor said it won't spin/agitate and I'm going over to look at it for them.
  No, that manual is for the hydrowave models, this one is an older (1997?) "T-style". Sounds like a bad lid switch. Washer would still fill and drain, but no agitate/spin. With this style lid switch, sometimes the white plastic part that the lid strike presses against will come off and end up at the bottom of the washer cabinet.
http://www.repairclinic.com/PartDetail/Lid-Switch-Assembly/WH12X1043/278249
Eric
Here's your tech sheet.
http://appliantology.org/files/file/1601-ge-t-style-washer-wjsr2080v1ww-tech-sheet/
Added tech sheet to Downloads section.
