LG dishwasher not working
5 replies to this topic
#1 hunt194
hunt194
  • 2 posts
  • Flavorite Brew:homebrew
Posted 15 February 2014 - 05:57 PM
I have a 2008 LG LDS4821ST and am not really happy with it.
A few months ago it started making an intermittent noise.  it was so loud that it could be heard through the whole house.  I replaced the sump assembly.  the noise stopped, but now it does not clean the dishes.  there is no water in the dishwasher, but it is full of dirty dishes.
When i installed the new sump, i checked to make sure all of the connections were correct.  the wires are connected to the same terminals that they were removed from.  And the water supply is turned on.
it seems like the water will fill at the  beginning of the cycle, but it will immediately drain out before the wash cycle.  when i add a few gallons of water mid-cycle. it seems to wash normally.
WTF?
How can i fix this?
#2 john63
john63
    Dean of LG Appliantology
  • 2,212 posts
Posted 15 February 2014 - 11:10 PM
A few questions...
1) What is the Serial Number?
2) What is the Part Number of the replacement Sump Assembly?
3) What is the *build date* of the replacement Sump Assembly (located at the bottom)?
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#3 hunt194
hunt194
  • 2 posts
Posted 16 February 2014 - 12:26 PM
  1. 808kwxd00906
  2. ajh31248604
  3. august 2013
#4 john63
john63
  • 2,212 posts
Posted 16 February 2014 - 12:48 PM
<<<808kwxd00906>>>
<<< seems like the water will fill at the beginning of the cycle, but it will immediately drain out before the wash cycle.>>>
I'd replace the GUIDE ASSEMBLY (4975DD1001A)---verify that the date of build shows February 2011 or newer.
Part number: AP4442244
The revised Guide Assy corrects several problems (water leaks/poor wash/fill-then-drain/etc)
Additional Info...
For the LG Dishwasher LDS4821 with Serial Numbers in the range of---804KWxxx to 906KWxxx---a Service Bulletin was issued to address infrequent "HE" errors.
The original Main Board is (EBR33469402)
The revised/improved Main Board is (EBR33469404)
Part number: AP4514740
The new M/B has a software change to be less "sensitive" to slightly higher-than-Target-Temperature (when the heater heats the water)
Edited by Samurai Appliance Repair Man, 16 February 2014 - 04:16 PM.
Added part links.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#5 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 982 posts
  • Flavorite Brew:orange juice
Posted 16 February 2014 - 01:14 PM
I don't know but could it be a siphon issue.  Maybe the drain hose is too low and not braking the siphon.  Just thought I'd throw that in as something to check.
Doc
#6 john63
john63
  • 2,212 posts
Posted 16 February 2014 - 04:05 PM
If the dishwasher "loses" water due to siphoning (low drain hose)---this will trigger an "E1" error.
Any error messages displayed, hunt194?
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
