AlexM
Maytag Refrigerator Model# MFI2067AES; Crazy Electrical Issues
26 posts in this topic
This Maytag Refrigerator with French doors and bottom  freezer is wacky.
The ice dispenser and lights on front are flashing and the flap motor is cycling constantly.
I can't find any obvious damage on the main board in back, and I reconnect all wires to board hoping it would reset.
Has anyone seen this before?  According to the customer, it might run fine for 15 minutes, but then goes to this wacky mode.
Manual might be handy?
Yep, it needs a new main control board. Not sure exactly why it does it, but I called tech support once on it and he immediately said it was the board. Changed the board and all good.
I concur with Bryan. High voltage board failure.
HV control board Part number: AP4014490
You Guys Rock!
I finally got around to donating to the beer fund.  Looooooooong over due!
THANKS FOR SAVING MY BACON, MORE THAN ONCE!      :thanks:   :thumbsup:
Mucho mega domos for your generous love-offering to my flavorite charity, Alex!  Glad we could help!   :pint1:  :cheers:
I'm a broken record on this (a stuck CD?? (an MP3 file that won't buffer??)) but when you see odd electrical stuff like this, check house electrical supply.  it's been really rare I have found a problem at the wall, (maybe six or seven times in three years) but in each case, if I hadn't checked it, I'd have been stuck chasing rabbits.
OK, so I put the new board in, and lights stopped flashing, but no compressor or fans,etc.
The only thing happening is the display show 'PEO OOO' is there some sort of sequence to reset the board?
Any help would be appreciated.
It needs programed I believe. Unfortunately, I don't remember the program sequence. Program number should be on your model #tag. I'll see if I can find the sequence.
Edited by BryanS
-Press and hold Door Alarm
-Press and hold Freezer temperature down
-Release Door alarm keypad and wait 3 seconds
-The control will display PE to indicate the programming mode
-Entry is confirmed by pressing the freezer Temperature down keypad once more
-The control will display the current program code. This value should be validated with the Program code printed on the unit serial plate
-Press the refrigerator temperature Up keypad or refrigerator temp downpad to change the digit value
-The decimal point indicates the selected digit. Press the freezer temp up keypad to select the next digit.
-Once the desired program cide is entered press and hold the freezer temperature down until the program code starts flashing indicating it has been saved .
*Unit will not run with code 0000
http://appliantology.org/files/file/416-maytag-ice-2-0-refrigerator-job-aid/
Page 35 of the manual
Edited by BryanS
thanks so much I will try it tomorrow
Now I'm really stuck.
I did the sequence several times, and I couldn't get it out of the flashing 0000 mode.  I'm slow, but not that slow...
I unplugged the unit and plugged back in, any ideas on what to do next?
May sure you are holding the correct buttons. I've gotten the freezer buttons and fridge buttons mixed up during the sequence.
Also make sure you are keeping the freezer temp down button pressed when release the door alarm button.
Might double check your connections at the board, make sure everything is in nice and tight.  I will neither confirm nor deny that I once put a board in a Samsung and forgot to connect the UI pins before putting the cover back on and putting the unit back against the wall.
Haha. Been there.
post-71964-0-43665100-1393115548_thumb.j OK still not there, but close.  I got it to the point that I put in the correct code 0202 in this case (see photo) and go to set the code and it beeps at me, like its a bad code...WTF?
Did you look at the manual? I didn't type everything out because I was on my phone.
O wait beeping is an invalid code
Edited by BryanS
You did press and hold the freezer down to set it correct? The only time I was unable to program a fridge was because the touchpad pad was bad or I did something wrong. I'm not sure what else to suggest
Is there a digit at the end of the model number on the Fridge ?
What Control Board part number did you get ?
I installed P/N W10310240
and I did press hard on the buttons...
I installed part # W10310240
According to your model number, APP pulls up P/N 12920710, which is the one I linked to earlier on Part number: AP4014490
Your model number is not compatible with P/N W10310240
Rats! my vendor gave me an alternate P/N that I could get earlier than 3 weeks. That will learn me.
(some model numbers use different Control Boards)
MFI2067AES
MFI2067AES4
MFI2067AES5
MFI2067AES6
MFI2067AES7
MFI2067AES8
MFI2067AES9
MFI2067AES10
MFI2067AES11
MFI2067AES12
MFI2067AES13
Edited by RegUS_PatOff
Just some information on putting code in. I had the same exact model number and code 0202. could not get it to take the code. So I tried the putting the code in from right to left order and the fridge took the code and is working!! Has anyone else had this happen?
