JennAir Range
Cascading Failures
13 replies to this topic
#1 john63
john63
    Dean of LG Appliantology
  • 2,211 posts
Posted 21 February 2014 - 12:04 AM
War Story of the Day...
A customer called with a complaint that *one* of the surface burners was not igniting (no spark)
JennAir Range/Gas
Model: JDR8895AAW
Serial: 14031292JA
Part Needed: Burner Switch Assy (5 switches in a harness) part # 12002792
Simple enough.
Cannot get the screws out of the burners (corroded)
Drilled all screws out---and now top cover can be removed.
Next problem...
Cannot replace the burner switch assy---unless two of the burner valves are removed (needed clearance to slide off 2 of the switches
Next difficulty...
Plugs for the switch harness can only be accessed from the back
Need to pull out the range (cabinetry on both sides)
Got that done---now onto the burner orifice assy...
Screws are *severely* corroded and will not "come-out"---even when MAPP gas is used until they're glowing embers...
Next on the list---gotta order 5 burner orifice assys and return in March (customer will be out of town).
Challenging to say the least...
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#2 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,452 posts
  • Flavorite Brew:What's on tap?
Posted 21 February 2014 - 06:48 AM
Been there - Cut and spice.
Mother Teresa
The views and opinions expressed in this post are those of the author and do not necessarily reflect or represent the views and opinions held by my employer. All data and information provided is for informational purposes only.
Big Brother
#3 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 937 posts
  • Flavorite Brew:orange juice
Posted 21 February 2014 - 05:08 PM
Does it ignite if you turn on one of the other swithches?
#4 john63
john63
  • 2,211 posts
Posted 21 February 2014 - 11:35 PM
<<<Been there - Cut and spice.>>>
That'll be the plan next time,Chat.
The real concern that I have is---how common is it for these JennAire/Maytag burner screws to permanently corrode/foul?
I was able to remove only 3 of them---they were not stainless steel either.
<<<Does it ignite if you turn on one of the other swithches?>>>
The center spark-switch was shorted (black-burn-residue)
Replacing the bank of switches was simple enough---except for the fact that 2 of the surface burner valves needed to be removed---to get adequate clearance. I'd rather not be disassembling *any* gas burner valve unless I'm replacing it.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#5 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 937 posts
Posted 21 February 2014 - 11:54 PM
Does that stove justify the parts and labor.  Is it a high end JennAir?  Does the blue book cover this job?  Just curious, seems like a lot of work, just wonder if it's worth it.  I think somehow it balances out in the end.
#6 john63
john63
  • 2,211 posts
Posted 22 February 2014 - 01:05 AM
It's a dual-fuel double oven,Doc.
I priced the job 395.00 for the ignition switch assy.
Now I need $90.00 (wholesale/dealer) in burner/orifice assys
Gonna "eat it" and move on :)
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#7 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 937 posts
Posted 22 February 2014 - 09:18 AM
Yeah I get it.  Win some lose some.  Like I say you have to take the good with the bad but it all evens out in the end.
#8 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,452 posts
Posted 23 February 2014 - 02:38 PM
Almost always.
Have learned to replace the switch harness without removing the top. It is tight quarters, but you can raise the top just enough to get at the harness with the burners still attached by unbolting the top and the valve manifold from the top. Just enough room to slip the wire harness off of the valve stems. Otherwise, estimate includes all burner bases, screws, wire harness, valve switch covers, etc..
Lesson learned: Always try turning the screws on any gas range burners before quoting the estimate. This is not the only model where heat and moisture seize those screws...
Mother Teresa
Big Brother
#9 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 937 posts
Posted 23 February 2014 - 02:50 PM
Confirm:  Had a GE gas last week.  Could only get the two front and the middle screws out.  Used needle nosed vice grip pliers, saved my butt a few times.  The Phillips fittings were rusted out.  Had to change 3 gas valves as well as switches.  It was tight but I was able to raise the top in front too.  What a mess, greasy gooie gunky mess.  Was an old customer and they were happy, The guy before me said it couldn't be done.  He was from GE
Doc
#10 -Mike-
-Mike-
    Kohai
  • 338 posts
  • Flavorite Brew:diet Pepsi
Posted 23 February 2014 - 08:41 PM
Most the frigidaire ranges have the burner screw problems too.
Keep a bottle of anti-sieze on your truck. Any time you're taking the screws out when the range is new and the screws are still removable  cover the threads so you'll still be able to remove the screws  in the future. There has been a few times I was glad I did that when I was out 5 years earlier.
#11 john63
john63
  • 2,211 posts
Posted 23 February 2014 - 11:16 PM
<<<Lesson learned: Always try turning the screws on any gas range burners before quoting the estimate. This is not the only model where heat and moisture seize those screws...>>>
Lesson learned,indeed :)
It's funny though---I've not had many gas cooktop/ranges in which the screws could not be removed *at all*.
Usually a little manipulation (heat/penetrant/viseGrips/etc) was successful.
Effective immediately: Test all gas burner screws first....  ;)
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#12 -Mike-
-Mike-
    Kohai
  • 338 posts
Posted 24 February 2014 - 01:19 AM
Thats a good policy to have.
#13 Scottthewolf
Scottthewolf
    Senpai
  • 2,905 posts
Posted 24 February 2014 - 02:42 PM
The best design I ever saw was the Maytag sealed gas burners that just twisted  to remove and install without requiring tools or just a round strap wrench. Screws are always a bad idea when heat, moisture and grease are involved.
Edited by Scottthewolf, 24 February 2014 - 02:43 PM.
Scott Wolf
#14 PDuff
PDuff
  • 2,013 posts
Posted 01 March 2014 - 04:21 PM
Same rule applies to the Thermador jet tubes.  I'll always make sure they can all be loosened before quoting the estimate.  If they can't, I'll shotgun everything.  Jet tubes, burners and base, even the supply tubing.
