Tool Backpack for Appliance Repair Service Calls
appliance repair service call tools tool backpack CLC professional
No replies to this topic
#1 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 29,160 posts
Posted 21 February 2014 - 06:35 PM
This is a continuation of my first video in this series, Tools for Appliance Repair:  http://appliantology...pliance-repair/
The previous video showed the bare minimum tools you should have with you, either in your tool pack or in your service vehicle, when you go on an appliance service calls.  There are some tools shown in this video that were not discussed in the previous one; these are tools that I've found to be handy or helpful but not mission critical.
- Ryobi P882 One+ 18v Lithium-Ion Drill and Impact Driver Kit  http://amzn.to/1gioD18
- Ryobi TEK4 4-Volt Screwdriver  http://amzn.to/1eTjXw4
- JH Williams WRS-1 Magnetic Ratcheting Screwdriver  http://amzn.to/1d1k88O
- BOSTITCH BTMT72275 Specialty Wrench Bit Set, 32-Piece  http://amzn.to/1hwedQR
- Genau Gear 3730 Soft Cushion All Purpose Knee Pads, Navy Blue  http://amzn.to/1jImDl5
- Motion Pro (08-0485) 6" Magnetic Parts Dish  http://amzn.to/1jdo4Za
- SKIL 2354-01 iXO 4-Volt Max Lithium-Ion Palm-Sized Cordless Screwdriver  http://amzn.to/1h7OnxU
- Fluke 117/322 Electricians Multimeter and Clamp Meter Combo Kit  http://amzn.to/1jdoK0B
- Milwaukee 49-66-4562 Shockwave 1-7/8-Inch Magnetic Nutdriver Set  http://amzn.to/1jRndQL
- 9 Piece Metric Quick Change Magnetic Nutsetter Set  http://amzn.to/1hwhwr8
- TEKTON 1916 Combination Wrench Set, SAE/Metric, 24-Piece  http://amzn.to/1fepHqj
- MAXCRAFT 60199 1/4-Inch Dual-Drive Mini Ratchet Driver   http://amzn.to/1h7O71X
- 62 Pc Metrinch Combo Spanner Socket & Wrench Set  http://amzn.to/1nOPFAa
- TEKTON 7609 Telescoping Lighted Inspection Mirror  http://amzn.to/ObGdMI
- IIT 21560 Pick & Hook Set with Rubber Grip - 6 Piece  http://amzn.to/Mds1km
- Stanley 28-140 1-1/4-Inch Nylon Handle Stiff Blade Putty Knife  http://amzn.to/1eTNfe0
- Linzer 7103S Plastic Putty Knives, 3-Inch  http://amzn.to/1mbbLhb
- GE 50725 Cable Ties, Nylon Assorted Sizes, 650 Per Pack  http://amzn.to/1fAurSa
- Sperry Instruments GFI6302 GFCI Outlet Tester  http://amzn.to/1eTOkme
- TEKTON 1491 3/8-Inch Quick-Release Drive Swivel Head Ratchet, 72-Tooth Round Head  http://amzn.to/1gXeYPk
- TEKTON 7597 36-Inch Claw Pick-Up Tool  http://amzn.to/1jdMVfq
- TEKTON 7601 Telescoping Magnetic Pick-Up Tool  http://amzn.to/MBRm8F
- Klein 11055 Klein-Kurve Wire Stripper/Cutter, Blue with Yellow Stripe, 10 - 20 ga.  http://amzn.to/1murbRa
- Klein Tools 1005 9-3/4-Inch Crimping and Cutting Tool for Insulated and Non-Insulated Terminals   http://amzn.to/1fi4xGk
- Custom LeatherCraft 1132 75-Pocket Tool Backpack  http://amzn.to/1feudoL
- Princeton Tec Apex 275 Lumen Led Headlamp  http://amzn.to/1murDPr
- Grease Monkey Gorilla Grip Gloves  http://amzn.to/1dOPgwD
- Custom Leathercraft 125M Handyman Flex Grip Work Gloves, Medium  http://amzn.to/1c3rJDP
- Knipex 002006S1 3-Piece Cobra Pliers Set (7-Inch, 10-Inch, & 12-Inch)  http://amzn.to/1muslMG
- Stanley 84-114 3 Piece Basic 6-Inch Slip Joint, 6-Inch Long Nose, and 6-Inch Diagonal Plier Set  http://amzn.to/MBTJIy
- Stanley 66-095 3/8-Inch Vinyl Grip Square Blade Screwdriver  http://amzn.to/1jRztAH
- Victorinox Swiss Army Deluxe Tinker, Red   http://amzn.to/1gXtfvv
- Victorinox Cordura Belt Pouch Swiss Army Knife Pouches Black 33214  http://amzn.to/1gHVA9u
- Bondhus 20399 Ball End L-Wrench Double Pack with BriteGuard and GoldGuard Finish  http://amzn.to/1oVHHby
- Irwin Industrial Tools 2078700 6-Inch and 10-Inch Adjustable Wrench Set, 2-Piece  http://amzn.to/1fBUgBf
- Irwin Tools 36- 2 Piece Original Locking Pliers Set Contains: 1 Each 7WR and 6LN  http://amzn.to/1ctBkXI
- Set of 6 - Heavy Duty 6-Inch Steel Spring Clamp with PVC Grip  http://amzn.to/MDKfwi
- MAXCRAFT 60626 8-oz. Stubby Claw Hammer  http://amzn.to/1bOzjrx
- Amprobe VP-440 Non-Contact Volt Detector  http://amzn.to/1jSDdBV
- Kintrex IRT0421 Non-Contact Infrared Thermometer with Laser Targeting  http://amzn.to/1bOAcQG
- McCulloch MC1230 Handheld Steam Cleaner  http://amzn.to/1gMPVyZ
- ArmorAll AA255 Utility Wet/Dry Vacuum  http://amzn.to/1ffKtFW
