Samsung RS265TDRS/XAA Evap Iced up
evaporator ice evap
25 replies to this topic
#21 KCTBURY
KCTBURY
    www.ieappliance.com
  • Chief Appliantologist
  • 109 posts
  • Flavorite Brew:Coke
Posted 27 February 2014 - 04:45 PM
I'm replacing the thermistor on the evaporator and then the cover.
We most likely have the same problem.
Edited by KCTBURY, 27 February 2014 - 04:46 PM.
#22 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 965 posts
  • Flavorite Brew:orange juice
Posted 27 February 2014 - 05:19 PM
I'm pretty sure it's the thermistor also.  Doen't hurt to replace the cover.  If they sell the package together with the fan for a decent price, I"d probably go for that.  Samsung is the worst for parts and customer support.  Good Luck
Doc
#23 mrtrojanap7
mrtrojanap7
  • 9 posts
  • Flavorite Brew:coffee
Posted 28 February 2014 - 12:54 AM
Okay. Great. Have you downloaded the fast track yet? Once you have that you can test your thermistor. The incomplete defrost from the out of spec thermistor could be causing this. Once you confirm that with the multimeter, change it and then defrost fan assy.
If you want to replace everything it could be. Replace the defrost thermistor and the evap cover with fan.
Got the fast track manual, got my multimeter. Saw the fast track manual diagram and got hesitant. Mind elaborating a bit more on which pins I have to test to troubleshoot the thermistor? The fast track manual only calls out a thermistor for heat release ice production...
#24 DurhamAppliance
    Sho' Nuff Chozin
  • 5,452 posts
Posted 28 February 2014 - 04:11 AM
What fast track are you reading? If you are looking at the proper fast track, all sensor pin locations are noted on the picture of the board. The one you are looking for is located at CN40 entitled Sensors and Switches on the fast track board markup... F defr sensor pins 6-4 (blue to gray)
Edited by DurhamAppliance, 28 February 2014 - 04:12 AM.
www.DurhamApplianceThrift.com
#25 mrtrojanap7
mrtrojanap7
  • 9 posts
Posted 28 February 2014 - 09:49 AM
I was looking at RS265TD Fast Track R1. wrong one, i'll try again tonight after work.
#26 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 30,182 posts
Posted 03 March 2014 - 04:39 PM
Sensor Part number: AP5583414
Evap cover Part number: AP5326112
0 members, 1 guests, 0 anonymous users
