xman1x
Mav7600aww Loud Washer
10 posts in this topic
The washer I'm trying to repair makes a high squealing noise when spinning and draining. Belt doesn't appear to be loose or have any cracks in it. Any ideas?
sounds like the water pump. part number 35-6780  try turning the pulley by hand should turn freely, with belt off.
Sounds like a pump to me to too.
Thanks for the quick replies. With the belt off... should a working pump turn freely or not by hand?
a working pump should turn freely
should turn freely
A common problem with these water pumps is the ball bearings will almost fall out of the pulley when they go bad.
OK. I'm stopping by the house again on Saturday. I'll remove the belt and check that out. Thanks everyone!
Problem solved with the new pulley. You guess rock!
Thanks for the follow up, good job.
