service manual for samsung ref RGS257AARS
chrisabaker12
Double check your model number (title and post show different numbers) then once you have the correct number, search download section... Check this video out for search methods http://appliantology.org/topic/47143-how-to-find-info-and-manuals-in-the-vast-repository-of-wisdom-that-is-appliantologyorg/
Edited by DurhamAppliance
