Brenrick
Kenmore 70 series washer
4 posts in this topic
Kenmore 110.26912690 model, the water level won't stop for size of load.
How do you get the water to stop overflowing? If it will stop by turning it off at the timer you have a bad pressure switch or pressure tube. If you had to turn the water off at the wall (the timer wouldn't shut it off) you have a bad water inlet valve.
1 person likes this
Pressure Switch Tubing may have a crack, became brittle, or clogged.
If the Tubing has ever been disconnected,
the Washer must be completely empty of water before re-connecting.
Edited by RegUS_PatOff
2 people like this
Did you have the cabinet off by chance recently. If so you may have the pressure tube caught/pinched in the back of cabinet. If so reposition tube towards the cut  out directly above the water inlet valve. Not that I have ever done this before.
1 person likes this
