Patricio
Kitchenaid Dishwasher KUDS30FXB10
11 posts in this topic
This dishwasher does not clean anymore.   Can't figure.  Cycles complete.   Spray wands spray, seems like plenty of pressure.  Glasses fill with water.  Run DW cleaner thru it.   Checked sump can't find hard water deposits.   Client uses Liquid Finish. Customer runs faucet until hot water is available.  I am frustrated.
 Run diagnostics, error codes are 6-2, 6-1, & 6-2.   all water fill codes    Water level seems normal.  Error codes won't clear.   Suggestions?   I read in Samurai's ASTI report that the diverter valve could be clogged.  .  Where may that be checked?
Did you access the chopper assembly clean out the mesh screen.? Very common on this model for that to get clogged with food particles.
This will block return water from circulating properly as well as rinsing with soiled water.
The diverter valve is on the new Global Wash System (GWS).  This one is the Point Voyager design with the chopper that Brother MA tech mentioned.  Very common failure.
Chopper Part number: AP4260709
First thing I did.  Pulled a little piece of plastic out of the filter the on my initial visit.  Ran it thru normal cycle & seemed like plenty of volume of water & pressure.   2nd visit, screen was clean & dispensor was not opening due finish pod not completly dissolved.   Cleaned dispensor put into diagnostic & everything worked except dishes being cleaned.  She shows me pans & bowls that are filthy after a wash.   Never a full load of dishes does she show me in person.
Every thing here points to water, as in "not enough water or not enough water in motion" I know the visual checks seemed okay but the error codes and actual results are going the opposite way.
Do all of your basic water checks: house pressure, no kinks in the supply line, correct drain hose install, control board holds voltage for the correct time, no foreign objects under float switch's float, o-ring in the garden hose fitting didn't fall to pieces, all that good stuff.
I recently had one of these where I had plenty of water, no clog in the sump, and terrible cleaning results, including undissolved detergent.
The chopper had seized up and broken to bits.  During test cycle, I put an amp clamp on the motor and it read "1.28".  Tech sheet says "normally 250 watts."  Not finding anything else wrong, I replaced the pump and sump assembly and that got the job done.
I checked the amp draw in the wash cycles.  At first I had 1.2 amp draw, then it stabilized at 1.7amps.     the diverter valve screen is clean but the chopper blade seems to free wheel.  Pulled the mechanism out & did not find it in pieces, It is loose at the end of the shaft the chopper blade.
I also had 120o water temp coming out of kitchen faucet, only 100-110 inside tube.   The water heater is old, lady says she has plenty hot water in bath tub.
I am going to order pump/sump assembly Monday.
Follow up post:  Installed new sump assembly with motor,   Put new turgidity sensor also.    Pump now pulls over 2 amps, machine is a lot quieter.  If this does not restore the  washability  factor I am going to quit the appliance business............................................for a day.   I think I'll take my yak & poles & hit the water.   Limits for specs & reds are there to be had.          Are you ready for some fish,,,,
If the mesh screen is clogged it will need to be replaced it it a plastic shaft and is broken.
Edited by MAPS Appliance Repair
Tell me if I am wrong, does that not come with the new sump assembly?
:banghead: I'm going fishing.   :wallbash:  :down:
Edited by Patricio
