jty1220
My GE Oven keeps turning itself off
4 posts in this topic
My GE Oven Model # JKP16W0P1WG will sht off only a few minutes after I turn it on.  I noticed it over the weekend.  I will set a temperature to bake and it will start warming up and after a few minutes it turns itself off.
Do I need to replace the whole oven?
I can't get your model number to come up. Are you sure that is the correct number?
If this is like all the other GE ovens with a simmilar model number, 98% of the time this problem is due to a bad electronic oven controler.  Its a very common issue with them.
Check your power supply first to be sure you don't have a bad connection with one of the power wires or the nuteral, and if all that looks OK replace the clock. Since I can't get your model number to come up I can't say for sure, but a lot of these clocks are discontinued in which case you will have to have the part repaired.
Yes that is the correct #.  I don't know how to do that.  Looks like I need to have GE come out
Concur with Brother Mike.  Could also be a bad cooling fan.
