sydmeg1012
Jenn Air PRG4810NP Gas oven won't heat properly
3 posts in this topic
Larger oven doesn't come up to temperature. The smaller left oven works fine, and the broiler in the large oven works ok as well. The ignitor will glow and ignite the burner, but I get a sputtering sound coming from the gas jet/port in the front that feeds the burner. This comes and goes, and when that happens the burner flames aren't as strong. Even when it doesn't sputter it still doesn't heat like it used to. Not sure if it's the spark ignitor or a bad or clogged port. Thanks for any help!
sounds like a weak "glow ignitor"
common problem, they get weak
Part number: 73001165
Thanks!  I was leaning toward that, will give it a try.
