4everJAZZ
Thermador PRDS48GDUS Range... HELP!.... needed
5 posts in this topic
I got a NEW Animal... His name is "Thermador". (Actually #PRDS48GDUS is his 'clinical' birth name). He's about 48 inches long, comes with 6 STAR burners and a griddle, has a gas and electric oven and likes to 'Click" a lot even when no one is around.
Do You know this Animal??? Have you SEEN this Animal??? Well, if so... then maybe you can help me understand This One.
I noticed that the burners, when turned all the way off (along with everything else), will start clicking on its own. (Board???), Buuttt... when I turn the L/F burner knob (second from the left) about 3/8 inch towards the 'on' position, the clicking Stops. And STAYS stopped... (Switch???) .
all the ignitors seem to be in relatively good position. I lightly sanded them and checked for any blockages at the burners. They ALL light by themselves (except 1- (M/F)( ignitor not sparking Anytime...). Thats the 2nd issue... but... if given a flame, it lights fine. And what tool do I need to remove the Nuts on the venturi(s) / spill trays???
Sooo... does this make any sense to anyone??? Is it 'clear' and 'understandable'??? cuz... i'm cunfewzzed!!!!!!
Please Help!!!
Correction...
The Full model# is PRDS486GDUS. but yes... I STILL need help!!! :wacko:  anyone?... anyone?...
Provided the electrical outlet the unit is plugged into is properly grounded and polarized and none of the ignitor wires are shorted to ground, I would suspect the spark module.  How is the oven function?  Any leds flashing?
All the burners or just the XLO burners on the LHS?
That LF burner is one of the XLO burners on this unit, unless I'm remembering wrong.
My apologies for just now responding back. I've been down with medical stuff last few days... But... back to this "Animal" im dealin with......
Yea, I couldnt get to the plug and couldnt pull the unit out ('back' issues...), so am going back with a second man. I will Definitely check the power there. I understand that its a "newly added addition" to the house. (must be nice- riigghhhttt???). but with the addition added im thinking that power mite b part of the problem.
And... Samurai... I know i should have remembered the visual set up of the unit... but failed to do so....  Forgive me Master!!! I am not honored enuff to work on the "Thermadors" very often, so That got past me, but I DO believe you r right... Question: are the potentiometers the same part number for all the burners? and wasnt there a 'replacement kit' offered at some point??? If so... do you (anyone know the part #'s). I found the re-ignitor module #, ignitor #, and potentiometer #... but i thought there was a 'kit'??? Ooohh... and its Only the L/F burner that has the 'anytime it wants to' clicking. and Only the M/F burner that has No spark at all. All the other burners work just fine. THX Family!!!
