Learn how to be your own tech line...
nursingguy
GSHF5MGXCEBB
6 posts in this topic
Hello All:
Refrigerator Model Number: GSHF5MGXCEBB
Problems:
No water dispensing, no ice making, no auger motion, no light in the dispenser area, and the digital readout on the freezer door is flashing 4 zero's (00 00). Now it is completely blank.
I have done the following:
Split the water line at the connector under the left front of the fridge and depressed the dispenser handle and it did nothing. I blew through the other end and it is clear, i.e. no frozen line.
I trouble shot the icemaker and found the molex connector was not pushed in all the way connecting the icemaker to the fridge. Problem solved, water valve now dispensing water to the icemaker and icemaker cycles fine.
I took apart the dispenser area and unplugged the interface board completely, I checked the micro switch and it is fine. The solenoid appeared to be fine as well. I put it all back together. I also looked in the ice bin and cleared out some stuck cubes.
At this point I plugged the fridge back in at the wall and everything came on appropriately. Remarkably, I was able to cycle the dispenser auger by depressing the cradle and it worked fine. I depressed the cradle and it gave me water, also the selector button worked when water was selected. The temp readout was reading fine.  8 minutes later, same problem. Flashing zeros, no water from dispenser and no auger motion, no light coming on in the dispenser area.
I looked over the main control board on the right rear, albeit much closer this time, and found what appeared to be a darker brown heat burn area on one part of the main control board. I replaced the board with a new board, same problems. I believe that some wiring needs to be removed/cut per the new board installation instructions. This fridge does have a run capacitor. See installation instructions for WR55X10942.
The doors are misaligned. I found out the door was replaced a few months ago. The freezer door extends a good 0.5" above the fresh food door and top of the fridge. I know that the water dispenser tube goes up through the freezer door cam areas, does some wiring as well? Perhaps we may have some pinched wires.
What are your thoughts?
Respect and thank you,
Mike
Pull the toekick off and check for a corroded wire or wires at the connection down by the water line. Usually if you give a slight pull they will slide right out if they are corroded and you will see blue inside them. I've been able to splice some of those if they are broken but might be better soldered and shrink wrapped because they are so thin. Maybe try a butt splice and them heat shrink over them.
Respect and thank you.
Mike
Was the freezer door the one replaced? If so the harness should be new but that doesn't mean the connector it hooked into doesn't have corrosion. Usually if the doors are misaligned it ia because a cam is worn. Sometimes they can adjusted by a screw. Other times the floor is uneven so it warps the frame to the point the doors are off.
Yes, the freezer door was the one replaced, but someone other than I. I looked at the cams and they appeared to be in good shape.
I think you are on the right track, now I am. I got under the fridge to initially look over the water dispenser line to see if it was frozen, etc. I probably joggled the connection harness at the same time as they are next to each other. It was after this that "everything worked".
Will go by again and review this are.
Thank you again..
Mike
Sounds good.
