Patricio
Kenmore (Amana) 596.50692000
3 posts in this topic
Can not find information on this SxS kenmore refrigerator in download section.  Having trouble understanding the water valve replacement part.   It has 2 solenoids but only one water outlet.  Part number 12544001.   says it has down a way with the 'y' system connection.    How does the valve send water to the dispenser without sending water to the ice maker & visa versa.    Problem was water inlet to IM was frozen & causing water to leak behind the refrigerator.    When I got the ice jamb defrosted, my next problem was inadequate water fill for ice maker.    When I use water dispenser I have good water volume.
Can I replace water valve assembly with another double whirlpool water valve that has 2 outlets?   Did not realize the original valve assembly had problems that the manufacture had to change designs.
Original wanted to request a manual for this unit but I entered in wrong forum, my apologies.
Edited by Patricio
uses (2) Dual Water Valves
Dual water inlet valve, primary (before water filter).
Replaces problematic plastic “Y” connector, includes instructions
Manufacturer Number 12544001
Water inlet valve for icemaker/water filter, secondary (after water filter)
Part number: AP4013367
http://www.repairclinic.com/Shop-For-Parts/a4b6c37d632293/Model-59650692000-Kenmore-Refrigerator-Valve-Float-Parts
http://appliantology.org/files/file/1630-amana-refrigerator-tech-sheets-t13063r1/
including water routing
Amana Refrigerator
Tech Sheets T13063R1
ARS2364A
ARS2364A
ARS2364A
ARS2664A
ARS2664A
ARS2664A
DRS2362A
DRS2362A
DRS2662A
DRS2662A
PARS2364AB0
PARS2364AC0
PARS2364AW0
PARS2664AB0
PARS2664AC0
PARS2664AW0
PDRS2362AC0
PDRS2362AW0
PDRS2662AC0
PDRS2662AW0
Edited by Samurai Appliance Repair Man
I suspected as much,  Thank you reg.    Called my parts dealer yesterday & was told there was only one valve listed for the unit.     What I get for not researching fully here.
