Learn how to troubleshoot like a Master Samurai Tech...
dryerman45
STACK UNIT
6 posts in this topic
Dear Master,
I have an Frigidaire washer dryer Model#FEX831CSO.The tub seal has to be replaced.Is there a bearing that should be replaced as well? Also does the nut turn clockwise to loosen when using the spanner?.I always forget
Thank you,
SAMANERA
I don't think so.  You can just change the seal if the bearings are ok.  Usually water leaking causes damage.  Is it noisey?  Inspect it while it's appart.  There is a rectangular plate that bolts to the transmission with two bolts and a part in back it screws into.  It pushes down on the seal to seal it with pressure and also holds the inner tub in place.   Sometimes those stack washer drters are hard to get the tub out.  I loosen the six or eight screws around the side of the washer on the bottom and slide the whole base forward.  Makes it real easy to work on.
Doc
dEAR mASTER, iAM NOT ABLE TO DOWN LOAD M,ANUAL HERE EITHER
tHANK YOU samanerta
Dear Master,
Thank you but Iam not able to download it here either
SAMANERA
Dear Samurais,
This unit has two bolts and a metal plate holoding the basket in.Used standard socket to loosen and pull basket out.Affter that took ring seal and main seal out.Only thing with replacing is be sure ring seal doesnt curl up while sliding down.Thanks for replies
SAMANERA
good job.  that's all there is to it.
Doc
