AlexM
Whirlpool Gas Range Model# SF262LXST : Replaced Bake Spark Electrode and Still Doesn't Light
3 posts in this topic
The complaint before I replaced the spark electrode on the bake burner was that it would click and spark but no flame, or only stay lit for 30 seconds or less.
I replaced the electrode and it does the same thing.
The broil works great, the burner on top work great, just no bake burner flame...
I have a solid connection between burner and cavity, so I think its grounded, don't know if that matters...?
Technical Service Pointer #: W10622771
Concern:
Under certain circumstances the Bake burner may not ignite. Sparking is taking place but flame is not established
Cause:
•Wiring harness may be pinched at a location between the Bake/Broil igniters and DSI Board.
• DSI Board mounting bracket may be contacting a solder joint on back of the board.
• Positioning of Igniter and gas burner igniter ports may be out of adjustment.
• Igniter (Electrode) deterioration
