417.44142400 washing machine manual
Tim M
  • Replies 1
  • Tim M
Nice of them to post it on the web.  I see there is no service manual per se.  Just wiring diagrams and tech sheet, so I guess this thing won't spit out error codes.  At any rate, a little movie I saw of yours will probably lead me to the correct diagnosis.  Many thanks for your help.
