frunch
Whirlpool dishwasher DU1300XTVS1 shuts itself off
12 posts in this topic
I just checked out a Whirlpool dishwasher where it will start a cycle, it fills with water, but as soon as it starts the main wash motor it shuts itself off. It does it consistently, tried it 3 times and it did it every time. When it shuts itself off, it shuts off the lights on the control panel. It can be started right back up, the buttons on the control panel respond properly. I'm thinking the computer is bad, but was hoping someone here can chime in with any suggestions to troubleshoot this further. I would just swap out the computer, but I don't have one in stock. Any ideas?
Thanks!
Trevor
Is it failing under load or does it go into drain right away?     Does the motor loose voltage when it stops?  How are the wire connections in the junction box? (Usually romex, but sometimes it is corded)
Edited by micabay
Open up the control panel and have a good look at the triacs on the control board-- you may see the one for the wash motor smoked.  But keep in mind that the absence of burned components does not mean the board is good.   It's just a obvious indication that it's bad.  Part number: AP4303742
I've had a few thermal fuses that open and reset even though it's supposed to be non resettable.
Interesting, Scott!  I've not seen that yet but will keep that in mind.
TCO Part number: AP4423189
I've seen similar but when they "reset" they usually measure at or above a couple hundred ohms.  Should be around 0 ohms if in good working order, Yes?
Also, a good idea to follow the instructions when installing this part.  New wires must be spliced in.  Can't just replace the fuse, for good reason.  The terminals may have a loose connection, causing it to heat up, opening the circuit.  Ask me how I know!   :rolleyes:
Edited by micabay
A thermal fuse is nothing more than a switch, you are looking for continuity, not ohms.   Ohms is a resistance value only used for loads, such as a motor, a solenoid, a wax motor or a thermistor.
If it's not load bearing, why does Whirlpool use such large gauge wire to that circuit?
Wire gauge is based on the current it has to handle-- large gauge wire is needed for larger currents.  In this case, current for the entire unit is passing through the TCO, including heater current when it comes on.  The wire has to sized to handle the highest current scenario.
That was my thought exactly!  Yet:
continuity test reveals if the wire is at least forming a complete circuit, yes?   If that circuit has 1, 10, 100, or 1000 ohms it would test good when testing for continuity.  This is why we check our readings, rather than just continuity.   If the TCO is partially tripped, it can test good for continuity yet not able to carry the current of the machine.
Most meters top out at about 50 to 100 ohms for continuity measurement.  It's rare for a TCO to partially trip-- more common for them to fail under load.  But if they partially trip, you'll typical see a resistance reading in the kilo-ohms range, far above the limit for the continuity setting on most meters.
I'll typically use the continuity setting on my meter when I'm chasing wires through an appliance or checking a cable harness for suspected breaks.  it's not unreasonable to use it for checking switches-- just unreliable.  Ohms testing can lie, regardless of meter setting, because something can check good on ohms and still be bad-- failing under load.  That's why I always prefer live testing.
Wow, glad this post sparked an insightful discussion! I learned a lot reading through the responses here, thank you all! Of course, since I left the dishwasher has been working fine! :woot:
I realize now that I forgot to add one important detail: I re-seated all of the connectors on the CPU, including the touch pad ribbon connector.  As a matter of fact, I just fixed a Kitchen Aid dishwasher that was dead (no lights coming on, won't run at all) a couple days ago by re-seating the connectors to the CPU. (Of course, I told the customer that the CPU and possibly touchpad would need to be replaced if the problem returns)
Either way, I'm sure they'll be calling back sooner or later. When they do, I'll follow up here!
Thanks again, everyone!
