MVWX700XW1 Maytag. Not enough water
10 replies to this topic
#1 Garpy
Garpy
    Ikkō-ikki
  • 38 posts
  • Flavorite Brew:Coffee
Posted 25 March 2014 - 03:17 PM
This is the first of these I've had in my shop. It has no error codes, runs nice a quiet BUT it just doesn't fill enough. I've read that some customers say these washers appear to not have very much water but the one I have is REALLY low. That can't be right! I'm asking if this may be normal for these machines or is it a problem and is it a fixable problem?
A regular laundry basket sized load is left probably 2/3 above the water level during the wash cycle. (after the machine senses how much water the load needs) The clothes just seem to get all twisted rather than washing and the tops layer of clothes are left not really being washed at all. Other brands but similar machines I've had seem to fill to a level of a couple inches of water above the clothes while this machine only fills to aprox a few inches of water in total.
Anyone familier with these?
Edited by Garpy, 25 March 2014 - 03:19 PM.
#2 sh2sh2
sh2sh2
    Senpai
  • PipPipPipPip
  • 706 posts
  • Flavorite Brew:yeunling
Posted 25 March 2014 - 04:31 PM
what cycle are you running it on? if its the normal cycle that is what the energy star tests are done on.  try a different cycle like heavy duty or casual.  on normal cycle with no clothes in the drum it will normaly fill with only a few inches of water
#3 Garpy
Garpy
    Ikkō-ikki
  • 38 posts
Posted 25 March 2014 - 06:50 PM
Hi. I will try a couple different cycles in the morning and get back. My original test was on Normal WITH a load of laundry so I could see how well the water level sensor worked. I assumed it would at least just barely cover the clothes. As is there simply is not enough water to actually wash with. I believe (quick estimate) that it's probably only about 2" of water int the tub With the full load of clothes.
#4 sh2sh2
sh2sh2
    Senpai
  • PipPipPipPip
  • 706 posts
Posted 25 March 2014 - 07:20 PM
sounds about right on the normal cycle
#5 MicaBay
MicaBay
    Master Roaster
  • PipPipPipPip
  • 831 posts
  • Flavorite Brew:Drifter Pale Ale
Posted 25 March 2014 - 07:45 PM
Take a few pictures for show and tell.  Also, try recalibrating the machine.  Have you tried unplugging it.  (ok ok that last one was a joke... :-)
#6 Thirstytech
Thirstytech
    Kohai
  • 393 posts
  • Flavorite Brew:Greenbush Starchicken Shotgun
Posted 26 March 2014 - 07:31 AM
Saving the planet one load at a time!  Welcome to VMW-land!
#7 Garpy
Garpy
    Ikkō-ikki
  • 38 posts
Posted 26 March 2014 - 12:30 PM
Ok, Re-ran it this morning. I spun the water out of the clothes in a different washer then put the load back into this Maytag. I spun the clothes out first to try to have the sensor not think it was a much larger load. I'm sure though that it still sensed it as a little bigger load that it is due to the weight of slightly wet clothes.
Here are two pics I took. One shows it paused mid cycle. The other shows with a tape measure just how low the level is. About 5" lower than the clothes. P.S. Sorry about the size of the images. I haven't yet figured out how to upload here.
#8 sh2sh2
sh2sh2
    Senpai
  • PipPipPipPip
  • 706 posts
Posted 26 March 2014 - 06:07 PM
is that on the Normal cycle?, looks about average, most people that have these washers find better washing results on other cycles besides normal
#9 Garpy
Garpy
    Ikkō-ikki
  • 38 posts
Posted 27 March 2014 - 11:17 AM
Yes, That's on the normal cycle. As this is the clothes re-loaded you don't see all the soap that was left on top of the clothes after washing on normal. Anyway, I'm glad to know at least that this is to be expected with these machines. They simply don't do a good wash on normal. It did do much better using the "Bulky" load setting.
Thanks all who were involved in helping out on this.
    Shōgun
  • Master Samurai Tech
  • 29,830 posts
Posted 28 March 2014 - 08:21 AM
An indication that they're using either too much or the wrong type of detergent.  Should be using no more than 2 tablespoons of HE detergent.
#11 Garpy
Garpy
    Ikkō-ikki
  • 38 posts
Posted 28 March 2014 - 10:28 AM
Hi
LOL. That's my testing in my shop. I used just over 1 1/2 tbs of Tide HE soap "powder" It works great otherwise. I'm just going to go with recomendation to customers to not expect great results from the "normal" cycle. What I have to decide now is whether I want to clean this machine up for resale or scrap it for parts. Damb morality Lol
