mountain golf
GE Monogram refrigerator ice maker problem
7 posts in this topic
Have a GE refrigerator, model ZISS48ONXSS that has been in a new house plugged in for 4 years, finally sold.  The ice maker is not working or at least it is not being activated.  Have water to the splitter in top, nothing in filter. Seems to be a problem with the icemaker calling for water. Any help would be appreciated.
Provided the green led is lit, you may attempt a diagnostic test cycle that will engage a harvest cycle followed by a water fill.
During the first 15 seconds that power is first applied to the icemaker, push the feeler arm from the "out" position to the "in" position and back again 3 times (and only 3 times) within 15 seconds.
Update on ice maker. The solenoid is not activating the water valve, have water to that point.
This icemaker does not have a green led.  I did try that combination earlier with no luck. The on/off switch is a white switch that basically pushes in the feeler arm, not black toggle type
On that ice maker, you can just move the fingers around by hand, say 180 degrees. It will then start running on its own.
I have tried that option also. I do have power coming in. Think I will get a new one to rule out if it is the icemaker or the refrigerator
Ice maker Part number: AP4345120
