Maytag Bravos washer (MTW6600TQ0) F70 code
f70 code high RPM spin cycle
7 replies to this topic
#1 ChrisandCheryl
ChrisandCheryl
  • 5 posts
  • Flavorite Brew:is it cold?
Posted 26 March 2014 - 11:49 AM
While back ago my wife and daughter said they were having problems getting the washer to program at the start of a wash (lights flickering, some controls not working) and also having issues with the washer during a wash cycle (washer stopping in the middle of cycles, not draining).  But now that problem has somewhat disappeared.  Now the only problem I see with washer now, it the spin cycle - guestimated at about 1 bazillion RPMs no matter on what the spin cycle is set on.  Which I didn’t think was much of an issue....faster the better, less work for the dryer in the long run?  However I don’t think the wife appreciated the state that her North face jacket came out of a finished load last night.  So I guess I better fix it.
I am able to get the washer into the diagnostic mode, F70 error.  But I don’t have any documentation on exactly how to test the washer in the diagnostic mode nor do I claim to be an appliance guru and properly use the diagnostic mode. I checked the drum area for any foreign objects that may have flown out during takeoff - didn’t see any.   I did check and reseat all the connections going into the control board (didn’t see anything loose), but that is far as I have gone.  Any ideas would be much appreciated, I think a new board is in the $ 300.00 range and I'll be happy to replace - but just want to make sure...$ 300.00 could buy a lot of beer…or maybe another North face jacket.
#2 bayouboy
bayouboy
    Sōhei
  • Chief+ Appliantologist
  • 154 posts
  • Flavorite Brew:Abita Beer Purple Haze
Posted 26 March 2014 - 12:26 PM
#3 sh2sh2
sh2sh2
    Senpai
  • PipPipPipPip
  • 885 posts
  • Flavorite Brew:yeunling
Posted 26 March 2014 - 06:08 PM
in my experience the most likely culprit is the MCU
    Shōgun
  • Master Samurai Tech
  • 31,409 posts
Posted 26 March 2014 - 06:48 PM
Guys, this is the Cabrio top-loader, not the Duet front loader.  F70 in these machines is the same as the oL error code.
Probably a stuck tub, not lifting with water fill.  Do the standard tear down and remove the cheese grater from the outer tub.  If it won't come out, you done found the problem, budrow.
#5 sh2sh2
sh2sh2
    Senpai
  • PipPipPipPip
  • 885 posts
Posted 27 March 2014 - 06:44 AM
damm whirlpool and there lack of continuity with codes between platforms, but yes check the basket to be stuck on tub
#6 bayouboy
bayouboy
    Sōhei
  • 154 posts
Posted 27 March 2014 - 09:47 AM
oops, so it is. make sure you are using the right amount of HE detergent.
#7 ChrisandCheryl
ChrisandCheryl
  • 5 posts
Posted 02 May 2014 - 08:11 PM
Can you maybe give me a quick pointer on if the tub is stuck.  How do you go about getting it unstuck?
    Shōgun
  • 31,409 posts
Posted 03 May 2014 - 05:13 AM
Some tips here:
