Maytag Epic Dryer turns on, controls work, beeps, but no go?
30 replies to this topic
#21 selwaycj
selwaycj
  • 19 posts
  • Flavorite Brew:cold
Posted 26 March 2014 - 11:11 PM
Takes a PhD to get that thing out without breaking it. The good news: I found the electric control panel. The bad news: I still haven't got the switch disconnected and I'm getting tired and cranky. I'll try again tomorrow with a fresh start.
#22 jbeckman713
jbeckman713
    Yamabushi
  • 63 posts
  • Flavorite Brew:Diet Pepsi
Posted 26 March 2014 - 11:17 PM
Part number: 8558455
#23 jbeckman713
jbeckman713
    Yamabushi
  • 63 posts
Posted 26 March 2014 - 11:42 PM
If you have the correct power, thermal fuse,  thermal cutoff, belt switch and door switch are testing ok you need a tech to come and run some tests with your control board to determine if a new one is necessary.
#24 sh2sh2
sh2sh2
    Senpai
  • PipPipPipPip
  • 792 posts
  • Flavorite Brew:yeunling
Posted 27 March 2014 - 06:40 AM
sounds like a bad motor relay to me, put your meter across the blue and black wires on the 2 pin connector on the main board, when the dryer is not "running" you should see 120v when your "start" the dryer it should drop to 0, if it dosent drop the relay is bad and u need a new main control
#25 selwaycj
selwaycj
  • 19 posts
Posted 27 March 2014 - 10:09 AM
Thanks for the continued help! I will follow your advice and troubleshoot after work again tonight, not giving up!
#26 stewartservice
stewartservice
    Sōhei
  • Master Appliantologist
  • 222 posts
  • Flavorite Brew:Yuengling
Posted 27 March 2014 - 10:29 AM
Have you checked cotrol board under lid top left? Look for burn mark on it.
#27 selwaycj
selwaycj
  • 19 posts
Posted 27 March 2014 - 10:45 AM
Not yet but I will, still have the lid off from trying to get the door switch out  :banghead:  There has to be an easier way to check that door switch!
#28 selwaycj
selwaycj
  • 19 posts
Posted 27 March 2014 - 07:37 PM
No burn marks on the control board. Stupid question, two pin connector blue and black wire???
#29 selwaycj
selwaycj
  • 19 posts
Posted 27 March 2014 - 08:16 PM
Need advice on checking the last two things, the belt switch and the motor relay. Thanks in advance.
#30 selwaycj
selwaycj
  • 19 posts
Posted 31 March 2014 - 05:25 PM
Got word today that a new control board is needed. Thanks for everyone's help and suggestions.
#31 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 30,579 posts
Posted 31 March 2014 - 06:01 PM
As in "Word from On High"?  Sounds mysterious!
Control board Part number: AP3775548
