Frigidaire Freezer mod # LFFU14F5HWN not freezing
6 replies to this topic
#1 Joe N
Joe N
  • 9 posts
Posted 05 April 2014 - 03:20 PM
This freezer quit freezing, I tested and  replaced the defrost sensor, but it didn't help. Fan is running, compressor is hot. Could it be compressor controller and or capacitor or door control module. Unit is abut 3 years old so I'm hoping it's nt the compressor.
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 5,787 posts
Posted 05 April 2014 - 03:27 PM
Check the evaporator to see if covered in heavy frost. If, take a picture of the evaporator after the fridge has been running for a while, then take another one 45 minutes later and post both pictures here.
www.DurhamApplianceThrift.com
#3 Joe N
Joe N
  • 9 posts
Posted 05 April 2014 - 03:36 PM
I will be glad to post picture, but it had no frost on it before  I replaced sensor nor since.
#4 DurhamAppliance
    Sho' Nuff Chozin
  • 5,787 posts
Posted 05 April 2014 - 03:38 PM
then we want to see the frost pattern on the evap to check if refrigerant is passing through it. Pictures at two different points in time helps assure we are not seeing the evap right after a defrost period.
btw is the compressor warm and vibrating, very Hot and vibrating or just hot?
Edited by DurhamAppliance, 05 April 2014 - 03:40 PM.
#5 Joe N
Joe N
  • 9 posts
Posted 05 April 2014 - 03:48 PM
Compressor just hot, didn't feel any vibrating. Pictures will be up soon.
    Shōgun
  • Master Samurai Tech
  • 30,622 posts
Posted 05 April 2014 - 04:05 PM
Sounds like possible bad compressor start device Part number: AP4393070
Are you hearing the hum-click cha-cha?  Periodically hums then clicks off?
#7 Joe N
Joe N
  • 9 posts
Posted 05 April 2014 - 04:39 PM
Thanks, just ordered part.
