Dishlexic
Amana ARG7102c oven stopped turning on.
5 posts in this topic
My friend's  Amana ARG7102c oven has worked fine for the last 9 years.  Last week it stopped turning on power and bass are ok, as the range still works, but no gas flows when oven is turned on.  (no smell, lighter doesn't work)  Where do I begin?
Begin by understanding how these ignition systems work:  http://fixitnow.com/wp/2009/12/17/gas-ignition-operation-in-a-gas-oven-with-hot-surface-ignition/
Then apply what you've learned to verify that the igniter is getting voltage and then measure the current flow through the ignitor.  Part number: AP4041245
If all these electrical measurements are new to you, you may want to enroll in the Samurai Appliance Tech Boot Camp.  The Beta class starts this Sunday.  If you're interested in being part of the Beta class, get your application in today and we'll talk about getting you enrolled.
shogun,
I am not worthy.  I'm better with electricity than with computers apparently.  I kept waiting for a little red box to tell me someone had replied to my question.  I had deduced on my own it was the ignighter just by walking away and using my brain, but you showed me how to find it  (unfurtunately I had to lie on my back to remove 2 screws unlike the video where they were on the back of the oven)  and test it.
line voltage present when I disconnected ignightor, but zero amperage after 30 sec.  Yes I reseated it.
so I've ordered the ignightor.
wish I'd done it days ago.  Just checking that Zero amperage isn't symptomatic of anything else.
thanks again!
Crazy easy!  Thanks so much.  And the dishwasher was fixed with the drop of solder you recommended.  my only problem was that I had switched to a liquid detergent, and as per your suggestion, I went back to the 2 part pellets, and voila! now it works.  Now If I could just get a part number, I could order new door hinges for my OWN oven.  Where should I look?  (it was not on appliancepartspros.com)
These hinges?
Part number: R0706011
Part number: R0706010
