FAQs | Store | Memberships | Repair Videos | Newsletter | Beer Fund | Contact
Ge washer model wcvh6800j1ww control panel
3 replies to this topic
#1 CheHoff
CheHoff
  • 2 posts
  • Flavorite Brew:Coffee
Posted Yesterday, 04:53 PM
Just replaced control panel for ge washer wcvh6800j1ww. Did not fix problem. Original problem was that after pressing power button and then the start button, the start button would flash and not start the cycle. It requires that the door be opened and closed repeatedly (pressing the start button after each closing) before the button will stop flashing and start a cycle. Do I have a door lock problem instead?
Edited by DurhamAppliance, Yesterday, 05:39 PM.
ADDED MODEL NUMBER TO TITLE
#2 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 518 posts
  • Flavorite Brew:orange juice
Posted Yesterday, 07:19 PM
You need to find the manual and run a diagnostic test.  Find the manual and check the door switch by testing it at the control board.  Other wise you will just keep changing parts until you get the right one.  It could be a bad connection in one of the cables or a loose connection.  You need to do some testing.  It does sound like it may be related to the door switch.  You could buy it from app and if it's not the problem you could send it back.Part number: AP3884122
  Better to find out for sure what the problem is but that's not always possible.  In that case you could order and if it's not the fix then return it.
Doc
#3 CheHoff
CheHoff
  • 2 posts
Posted Yesterday, 11:00 PM
Thanks for the fast reply. Ran the diagnostic test -- no errors identified. I took off the cover and discovered that one of the plugs for the switch was loose. Reseated the plug, threw in a load of laundry, and it is working! First time it has worked correctly in days... Thank you for your help.
#4 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 518 posts
Posted Yesterday, 11:35 PM
Good job CheHoff and glad we could help.  That deserves a cold one! :pint1:
Doc
