Zip Programs
8 replies to this topic
#1 Adirondack Bob
Adirondack Bob
    Kohai
  • 307 posts
Posted 18 April 2014 - 10:13 PM
This in regards to a recent post in the Dojo.
I have downloaded a Zip file and when I try to open it, I get an error message that Windows cannot open the file. I am guessing that I need a Zip program to open it. I see that Winzip costs $30.00. Wondering if there is a good free one that anyone suggests, or should I just go ahead and purchase the Winzip.
I am running Windows 7 OS.
Thank You, Bob
#2 LI-NY Tech
LI-NY Tech
    We Fix Shit Great!
  • 1,040 posts
  • Flavorite Brew:Six Point Brewey Hi-Res IPA
Posted 19 April 2014 - 06:02 AM
Windows 7 should unzip automatically, no need to purchase.  Could be an issue with the file itself.  If you want to download all the files yourself from that page use the Firefox browser and install the DownloadThemAll! extension.  The browser and the extension are free and easy to use.
David
RD Appliance Service, Corp.
PO Box 234, Bethpage, NY, 11714
516-561-0523
http://www.rdapplianceservice.com
#3 Budget Appliance Repair
  • Senior Appliantology Fellow
  • 5,155 posts
Posted 19 April 2014 - 06:06 AM
Also, try right clicking your mouse on the file and see if maybe the drop down option menus contains an option to unzip, (Zip program is usually standard installation on Windows - but I have no experience past XP so don't know about Vista, 7 or 8).
Check the 'Open With..' or 'Send To..' option if you see that on the list, (that's were the access to Windows XP zip programs are).
Edited by Budget Appliance Repair, 19 April 2014 - 06:10 AM.
William Burk (Willie)
Eureka, CA 95501
#4 DurhamAppliance
    Sho' Nuff Chozin
  • 5,909 posts
Posted 19 April 2014 - 06:39 AM
Winzip use to be freeware... man, I'm getting old.
www.DurhamApplianceThrift.com
#5 Radio Loco
Radio Loco
    Kohai
  • Chief+ Appliantologist
  • 296 posts
  • Flavorite Brew:Ginger Ale. On the rocks.
Posted 21 April 2014 - 10:41 AM
Hi David,  Thanks for uploading the file Bob is referring to.  I had the same experience as Bob.  I use Windows 7 Home and Firefox. I dl'ed the free Winzip evaluation version and it pretty much just sat there and did nothing. Got the same error message as Bob.  Tried 3 different downloads of the huge file.
Then tried my wife's cp with 4G memory and plenty of hd space and got the same results  (Windows 7 Home Premium and Firefox also).
We also tried 7zip, and it would only open about a third of the files, mostly the use and care manuals.  Some progress, but still frustrating.
Any chance you could upload a NEW file so we can try again?  Thanks for your help.
I think this will work. I downloaded the app.
Or, on the other hand.....
Troubleshooting modern appliance's complex electronic and electro-mechanical systems is the methodology in which one must, by using analyitical techniques and the process of elimination, determine the cause or causes of a specific failure. Rarely does this cause of a failure directly present itself for you to see.
So.....To be better equipped to troubleshoot, you will need:
1.) To follow this: Safety first and foremost. Heed to and trust your instincts.
2.) Basic hand tools.
3.) A decent DVOM meter. Buy one. Borrow one. You need one.
4.) Last, but certainty not least, common sense. Most of us have it. Slow down and use it.
Now, let's have some fun!
ZIG:
Hope is the power that gives a person the confidence to step out and try.
Success is the maximum utilization of the ability you have.
N.M.:
It always seems impossible until it's done.
For those that will fight for it...FREEDOM..has a flavor the protected will never know.
He calls me friend !!!!!
#6 LI-NY Tech
LI-NY Tech
    We Fix Shit Great!
  • 1,040 posts
Posted 21 April 2014 - 03:40 PM
I actually didn't upload the file to Dropbox, someone else did.  If you're using Firefox install the DownloadThemAll! extension (Google it) and visit the web page in question.  Use DTA to download every file on the page as individual PDF files, no unzip needed at that point.
Click HERE to go to DTA download page.
Edited by LI-NY Tech, 21 April 2014 - 03:42 PM.
David
516-561-0523
#7 Spannerwrench
Spannerwrench
    Mutsuhito
  • 1,132 posts
Posted 21 April 2014 - 07:10 PM
Try to fix the windows extract feature.
http://support.micro...nd_folder_diag/
"Suds are not good"
"Occam's Razor 'the simplest answer is most often correct'"
#8 Radio Loco
Radio Loco
    Kohai
  • 296 posts
Posted 23 April 2014 - 01:39 AM
Thanks guys for the help. I'll give it a try.  :imnotworthy:
ZIG:
N.M.:
#9 steveklein
steveklein
    Ikkō-ikki
  • Appliantologist
  • 49 posts
Posted 02 May 2014 - 05:13 PM
Zip file support is built-in to Windows 7. You don't need any other product. My guess is that there's something wrong with the file you downloaded. It might be damaged somehow.
Try downloading it again. If you get the same error message, post that message here and I'll try and help you figure out what's going on.
Steven Klein
Mac, PC & Network Expert
