maytag dryer model MGDE300VF0 works fine then stops...... then starts
29 replies to this topic
#21 keithnellie
keithnellie
    Ikkō-ikki
  • 21 posts
  • Flavorite Brew:french market dark roast
Posted 04 May 2014 - 08:50 AM
Checked the 220 and it was 294 so I called the power company and they sent out a crew with a new transformer. Seems that with the underground transformers after a lighting strike instead of frying the transformer it does something inside where the voltage increases. They see it all the time. I will discuss filing a claim because i just replaced a well pump to the tune of $1800 that was only 4 years old along with the washer and dryer.
#22 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 936 posts
  • Flavorite Brew:orange juice
Posted 04 May 2014 - 09:17 AM
So what is the end result?  Is your washer ok now or are you just getting a new one.  Seems yours might work ok when you get the new transformer.  What's the latest?  Glad you were able to figure it out.
Doc
#23 keithnellie
keithnellie
    Ikkō-ikki
  • 21 posts
Posted 04 May 2014 - 01:46 PM
Don't know for sure yet. I am working 12 hour nights for a couple more days and with a 1.5 hour commute each way it doesn't leave much trouble shooting time. I don't know if any permanent damage is done but most electronics can take over voltages so if the motors still work I may be okay. I will post again when I have a day off.
#24 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 936 posts
Posted 04 May 2014 - 04:25 PM
Ok thanks, waiting patiently for you reply.
Doc
#25 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 30,016 posts
Posted 04 May 2014 - 05:38 PM
My humble opinion:
#26 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 936 posts
Posted 04 May 2014 - 06:01 PM
My humble opinion:
<script type="text/javascript">(function() { var po = document.createElement("script"); po.type = "text/javascript"; po.async = true; po.src = "https://d15mj6e6qmt1...et/cdn/embed.js"; var s = document.getElementsByTagName("script")[0]; s.parentNode.insertBefore(po, s); })();</script>
Yeah, kind of figured that but still holding out hope.  At anyrate be good to fix this voltage problem before proceeding to the dryer proble.  Wouldn't you concur?
Doc
#27 Samurai Appliance Repair Man
    Shōgun
  • 30,016 posts
Posted 04 May 2014 - 06:49 PM
Oui, papa.  Sumpin ain't raht w'dat vo-tage thang.
#28 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 936 posts
Posted 04 May 2014 - 07:21 PM
Thanks youngun, we old folks can use a little help now and again.  Even though I forgot problably as much as you know, it nice to have someone around to point us in the right direction now and again.  Thanks Bruta
#29 keithnellie
keithnellie
    Ikkō-ikki
  • 21 posts
Posted 07 May 2014 - 09:22 AM
It appears the problem was solved by the new transformer. Both the washer and dryer have done multiple loads with no issues. It is amazing how well it all works when they have the correct voltage.
I will now know to check my voltages at first sign of trouble. I guess that is what they call "experience".
#30 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 936 posts
Posted 07 May 2014 - 05:55 PM
Good job, glad to hear everything is better.  Thanks for the follow up.  :thanks:
Doc
