strudles
Trying to replace gearcase shaft seal Kenmore washer 11020922990
31 posts in this topic
This is a gearcase for a Kenmore mod# 11020922990 washer.
I'm trying to replace the shaft seal in the top cover of the gearcase (part # 3349985), but am having a terrific time getting the old seal out. The old seal had a tear in it, hence the oil that was leaking out into my clutch causing my washer not to spin properly.
Anyway, I pulled out as much as I could, but it almost seems that it's glued in as the sides of the seal are not coming away from the metal. What would be the best way to get rid of the old gasket rubber before trying to put the new one in? I saw the advice from post #9 here (http://appliantology.org/topic/36964-whirlpool-gold-direct-drive-washer-gsw9650lw0-transmission-or-clutch-can-i-repair-transmission/), I will try to do that if I can find the plastic "tail piece." The old seal in that post looks intact, like it came out nicely. Mine wasn't like that at all.
Also, the oil in the transmission was dark and silty and had lots of dust and what seem to be metal shavings in it so I plan to take everything out so I can clean it out before reassembling and re-adding oil.
This was a new transmission last summer/fall; should the seal and oil have degraded so quickly in that short a period of time?
Thank you,
Trudi
Edited by DurhamAppliance
added make and model number to title
I've seen this video, it's a good one, but it doesn't help me know how to get the old rubber off the top shell of the gearcase. Is there anything that would soften or dissolve the rubber or would sandpaper work? Not sure where to go from here...
I would try using a single edged razor blade. Scrapping it off. It is the tool I used when cleaning my head gasket off on my old toyota 4runner.
I posted a few pictures a while ago on this repair, cannot find it.But here is a few pictures of the repair "Tool".......4152011036.jpg......and  4152011031.jpg..and 4152011025.jpg.....In the first picture is the wooden jig I whiped up to hold the gearbox......The plastic "tool" is a plumbing piece called a "tail piece", it attaches to the out let on your sink drain..........30 wt. motor oil, non-detergent, is what I top -off  the gear-box with....
Edited by certified tech group 51
2 people like this
I'll try a razor blade, hope I don't scrape up the metal too much, though. The surface seems a little concave so not completely flat which makes it a bit more of a challenge.
I have never had one of those leak.  Not saying they can't but just wondering if maybe you had too much oil in the gear case.
Doc
There's no way to get too much oil in the gearcase, (unless you use a little syringe to inject it into the tiny vent hole on the top cover).
The correct oil level is just to the top of lower gearcase.
The shaft seal was cracked when I went to take it out (before I had done anything to try to remove it).
I got the gearcase apart and the oil was so dirty and sludgy looking and there were lots of slivers of something (plastic wearing off from the neutral drain gear maybe?) and dust so I poured out all the oil and will refill with fresh oil before closing up. I do have a question about the best way to clean the plastic gear as well as getting all the old oil out. I wiped out what I could with a paper towel making sure not to leave paper towel residue, but there are a couple of places I can't reach. Is it necessary to do a deep clean or will it be ok to just put new oil it as is? Is there anything I could "rinse" the gear with or soak it in to clean it better, or is that even necessary?
I still can't get the rubber off the gearcase cover (around shaft opening where old seal was). I tried freezing it and will see if that makes the rubber brittle enough to chip off. Doing a web search for things that would dissolve or soften rubber I read about gasoline, acetone or ammonia. Anyone have any thoughts in this department?
Thanks, I'm itching to get everything back together and get us washing again!
Trudi
The seal is press fit into the recess of the cover..........Possibly some one had previously "repaired" the leak/seal...................................Press out and press in the seal , no gluing in the seal..................You may have to use an X-Acto type knife and clean all the  pieces out of the seals seating area............Your first post sez it was new...................New  or a Whirlpool 'reconditioned / rebuilt'  unit ????........
1 person likes this
As far as I know, it was new. We bought it as a new transmission from a local appliance parts place.
Thanks to my son (13), the old seal is OUT! :woohoo: I was way off, the rubber wasn't bonded to the transmission cover, it was part of the seal and I didn't realize it. So that's done, but he and I are having a hard time getting the new seal in. I tried the tail piece (which I am borrowing from our bathroom sink), but I don't have any Windex, is there anything else I could use to help ease it in? Neither of us are having much luck getting it in. We're so close!
Thanks for all your help so far!
Trudi
use some dishwashing liquid.  Works great.
Whew, finally got it in. DH got the correct tail piece (mine didn't have the lip at the top) and managed to strong-arm the seal in. But now I'm having other issues to the point that I'm about to chuck the transmission as far as I can throw it, but that's for another post. Thanks for all your terrific help, it was greatly appreciated.
Trudi
Kenmore Elite 90 Mod# 11020922990
I took my gearcase apart to replace the shaft seal (history here: http://appliantology.org/topic/48399-trying-to-replace-gearcase-shaft-seal-kenmore-washer-11020922990/) and put everything back together per theapplianceman's YouTube video here (https://www.youtube.com/watch?v=ieZ5y47TAMk). When I got it all back together (after gasket had had some time to set up), the washer agitated nicely, but when it came time to spin, it drained out and made noises like it was spinning, but no spin. I took the motor off and tried to turn the drive coupler by hand to see if the clutch did anything and it didn't, neither CW or CCW. So I took the gearcase back out, opened it back up and had a look.
What I've noticed is that I can hold the plastic spin gear and keep it from turning while I turn the drive coupler on the side of the gearcase. Is it supposed to do that or should it turn in spite of resistance?
Something that maybe is beside the point is that when I was turning the drive coupler, it didn't turn nice and smooth, in fact when I took all the parts out, the gear (shown in this picture, don't know it's name, http://www.davesrepair.com/drsn/PC120044.JPG) in the bottom of the gearcase seems to catch when I turn the coupler, CW or CCW, doesn't seem to matter. When I put all the parts but the spin gear back in, I can turn it by hand for a little while, then it seem to get hung up and doesn't want to turn anymore. All this might be perfectly normal, but this grasshopper wouldn't really know the difference as this is the first time inside the gearcase for me. I'm just trying to figure out why the clutch won't spin, whether the spin gear slipping is normal... I've gotta troubleshoot this thing, it's driving me crazy! (Well, that and the laundry piling up all over the place) :wacko:
Thanks in advance for your help,
Trudi
You may not have the marks on the shaft gear and the agitate gear matched up.  the one line in the middle of the other two lines.  This will cause it to bind up when you try to turn the gear case gears.  This is one problem.  I think you had that right before you took it apart again because you had it agitating but not spinning.  I think you must not have the neutral drain parts in right.  They need to engage the plastic wheel in order for the washer to spin.  You can check if you have it right or not before you put it all back together by turning the transmission gear by hand,  one way for agitate and the other way for spin.  Maybe you need to look at the video again and follow it closely.
Doc
topics merged
1 person likes this
Plastic wearing off the neutral drain gear maybe?  If the main spin gear/plastic had teeth wore off it, then it's not going to spin!
I was wondering if it might be a worn spin gear too, but didn't have a new one to compare it with.
I did make sure that the connecting rack mark lined up with the mark on the agitate gear so I'm sure it wasn't that.
Here is a video of my gearcase. http://youtu.be/TsUiXYJIY3E
I figured out the jerkiness with the spiral gear in the bottom of the gearcase, it was just how my gearcase was sitting on top of the bucket I had it on. Once I moved that, it cleared up. But the whole works do bind up a bit at 1:15 and it was hard to turn the drive coupler, but then it did get easier. I started turning CCW, then CW. Spin gear still stays stationary when I hold it, shouldn't it keep rotating so that the clutch will turn? Is there a special way to put it on so that it lines up with all the parts on the neutral drain assembly?
Here are closeups of the spin gear:
All neutral drain pak parts appear to be installed correctly, (all parts are marked 'UP' on side that goes up).
The first and third pictures of the spin gear look like all is OK with the spin gear but the second picture kind of looks like there might be a step out at the bottom of the gear, (top section where metal spin pinion gear rides maybe worn off), but that might just be an optical illusion in the picture, I can't really tell - usually when the spin gear strips it is quite obvious lacking the teeth.
Watched the video and it appears the spin gear is in good shape.
Did you by any chance get impatient when you first tried it in spin and not wait the two minutes for it to drain, (it neutral drains - meaning the motor runs and pumps out but transmission will not spin the basket until the lid is lifted to let the motor stop or the pause that the timer has after the two minute drain which stops the motor and releases the latch in the neutral drain mechanism - then it should spin when the motor starts up again).
If the timer doesn't pause after the two minute pump out the transmission won't shift out of neutral - lifting the lid would simulate the timer pause and it should spin if the timer is possibly bad and not giving the pause after the two minute pump out phase.
1 person likes this
Thanks for your response! So, it's not a problem that I can hold the plastic gear from turning? Also, when the transmission was still together I tested it by turning the drive coupler on its side to see if it would cause the clutch to turn, which it didn't. Maybe that's not a real test, I don't know, but I was thinking that the clutch should do something when I turned the coupler.
I thought I waited enough time for it to go into spin last time, but maybe not. I guess I'll put it all back together and try it again if you can't think of anything else I should do first.
Trudi
I think maybe because you are turning it slowly by hand and you have no oil in it that it may not be engaging.  I'm with you for trying again and try lifting the lid after two minutes to let the motor stop and then start it again and see if it kicks it into spin.
Doc
Trudi:  I'm not sure if it will engage by hand.  When I test them I Hook it up to a variable speed drill.  I made an attachment to go on the shaft of the transmission to allow me to bench test it.  Maybe you could try that before you go to all the trouble of putting it back together again.
Doc
Ok, here's the thing Trudi.....  I just had a brain f--t and I remember one time not putting the spin gear cam on right and having your same problem.  It has a spring clip on it and it has to be facing so the spring clip is closest to the gear when you put it on.  It's on the bottom of the spin gear and when it is in right you can read (this side up).  I had it in upside down one time and it would not activate the neutral drain.  I didn't see any pics of the bottom side of your gear.  Have a look at that and let me know if this isn't the problem.
Doc
