Kenmore Oven Door Lock Problem - 911.4742594
26 replies to this topic
#21 Pegi
Pegi
  • 13,120 posts
Posted 28 November 2005 - 08:55 AM
Sounds like something is stuck in your control board...have you tried cutting the power to the range for a few minutes and then see what happens when power is restored? If it keeps doing this would suspect something is hanging in the range control...
#22 Guest_Uhoh_*
Guest_Uhoh_*
  • Lurking at the Threshold
Posted 28 November 2005 - 11:36 AM
I did try unplugging and replugging it in however, it just goes right back to the flashing "lock" (not light) button and continuous locking and unlocking. Do I need to get into the locking mechanism to fix this or replace something like a control panel?
#23 Pegi
Pegi
  • 13,120 posts
Posted 28 November 2005 - 11:46 AM
Have you found the model number so we can see who made this for Sears and possibly find some information??  You will need to see what is feeding voltage to the lock assy when it is doing this, if it goes back to the control panel and these wires un-plugged and this behavior stops, would tell you where the problem might be.  You could have switches shorted in the lock assy but no one has any idea what sort of lock assy this has without the model number....:?
#24 Guest_Uhoh_*
Guest_Uhoh_*
Posted 28 November 2005 - 06:30 PM
Sure did, the model number is 790-95262991 and the serial number is VF04310388.
#25 Pegi
Pegi
  • 13,120 posts
Posted 28 November 2005 - 06:57 PM
Ok, Frigidaire range with the Kenmore name on it, will see what we can find out tomorrow....
#26 Pegi
Pegi
  • 13,120 posts
Posted 28 November 2005 - 07:01 PM
I will start by posting the WIRING DIAGRAM.....wonder if the lock motor relay could be shorted??
#27 Oscar
Oscar
  • 2 posts
Posted 05 December 2005 - 06:00 PM
I solved the problem by starting the self cleaning cycle and then cancelling it. It flashed the same error code but then unlocked and cleared the display. I recommend that anyone else with a locked oven door try the same before attempting to manually unlock it or replacing a control.
Thanks again for your input.
