jambatt
GE Dryer GTDP200EF1WS
14 posts in this topic
Dryer is about three months old. Was workig fine until a few days ago when it would start but would shut down when start button was released. Customer had placed a rock on the switch so she could finish drying aload. Hold the start button and unit runs. Release the start button and unit shuts off. I'm thnking motor switch. Anyone run into this before??
Yes, the GE dryer motors are famous for getting lint stuck in the motor centrifugal switch.
Could be belt switch, too. Many of them are of less than firm construction and bend easily.
Good to know, I've never seen this happen though, although I think the motor will act like this if the belt is brocken so theoretically this is a possibility.
Doc
Nope, the broken belt switch wouldn't even let the motor start.
Not on the newer dryers. I had my warranty guy fix one. Check the wiring diagram. The switch only stops the motor, it doesn't prevent it from starting.
News to me.
News to me.
Me too, good to know though, thanks oly!
Doc
  Start switch bypasses the belt switch. Belt switch is not even in circuit until motor starts at which point it's circuit is completed by the motor switch. Always been that way on GE models.
Eric
So just to clarify then, the dryer will run when you push the start switch but if the belt switch is broken or the belt is broken then it will stop as soon as you release the start switch.
Correct?
Doc
Correct?
Doc
Yep.
It was the belt switch. Gotta luv those GE engineers. They do stuff like this to mess with us old guys. Danged young whippersnappers.
They must be using a cheap switch these days!  I've seen GE's 20 years old with the original switch still working fine.  Good to know, thanks for the follow up.
Doc
On the ones I've dealt with the switch is fine but the coat hanger wire they make the idler support out of was bent funny.
