  • Announcements
Scottthewolf
GE washer model # WHDRR418G2WW
10 posts in this topic
OK Folks, this washer wants me to get my rifle out and shoot it.  Model # WHDRR418G2WW.
I have replaced the main motor and inverter assembly for  a previous problem, the timer for a previous problem.  Now the customer told me she washed her dog's bed and the machine now does everything except agitate. It fills with water, sits there, no noise from the motor or anything at all,the timer advances to the drain and spin cycle, drains the water out and spins like it should. When you lift the lid to take the clothes out and then close the lid (even though the timer is in an "OFF" position, the mode shifter clunks and moves the wash basket a few times.  The motor status light indicates everything is fine with the drive system.
  PLEASE don't tell me the machine now needs a mode shifter assembly, the customer doesn't want to spend any more money on this machine.  I really think I just have another bad timer because the motor doesn't do anything when the tub is full of water.
Edited by Scottthewolf
McFLy??? Anybody home?  Beuhler??
Did the dog bed rip open and dump the hollifill? Had similar call once where customer did same thing. Took three trips and burned out a shop vac trying to get all the crap out from between the inner and outer tub.
Nope, drain pump is completely clear, the unit spins fine, it just won't agitate.
So, does anyone agree with me that it's a bad timer? I hope it's not a bad mode shifter assembly!
Knock Knock, McFly??? Anybody home?
i know somewhere there is a chart saying what voltages should be at what wires at the motor during different modes. i know its not on the tech sheet but i know i saw it somewhere,
I installed a new timer today, it didn't fix the problem, unit fills with water, does absolutely nothing during the agitate cycle, but timer still advances  to the drain and spin cycle, unit drains and spins.  Motor checks out good, no fault codes, so all I can think of is a bad mode shifter. Customer refused to sink any more money into this machine after I already replaced the motor and the timer a few years ago. I'm getting this piece of junk when she buys her new washer, so perhaps I can switch out a mode shifer from another scrap GE Hydrowave washer  I have laying around the shop from another customer who could not  see putting close to $400  in repairs.
I will never reccommend another GE product again.
what about the water level switch?  Had one just like this last week!  Not sure about the timer advancing though it did fill and shut the water off,  it switched to agitate but the points inside the water level switch never told it to agitate.  1st one I've run accross.  Thinking maybe this could be your problem, it was a GE also.
Doc
Edited by electro_doc
bad mode shifter would not cause it to not agitate, the only thing the mode shifter does is shift between the modes, when they are bad and dont shift it still agitates just moves the basket back and forth instead of the agitater, if the new timer didnt fix it and the wiring between timer and motor is good then i suspect a faulty motor/inverter
