zachp89
Whirlpool SxS Refrigerator wont shut off
7 posts in this topic
 Alright so I have this side by side refrigerator that wont shut off -20 in freezer and 23 degrees in refrigerator section. Figured it was the temperature control part number 2198202 so replaced that. Didn't fix the problem. Soooo I decided to try to turn the unit off but when I turned to the off position the unit wouldn't even shut off. So my next step was deciding to pull the temperature control out of the refrigerator and not have the temperature control wires even plugged into anything, plugged refrigerator back in without a temperature control inside the unit and it STILL turned compressor evap motor and condenser motor on. This unit has an adaptive defrost control board in it. Was wondering if maybe this could be whats causing this thing to never shut off and get refrigerator to freezing temps and freezer to really low temps as well. Feedback appreciated, Thanks
Need make and model number.  Might be a stuck relay on the central control board.  Just a guess, need model number.
Doc
Kenmore (Whirlpool) 106.57562792
I would say you are on the right track with the control board.  I don't have the manual, maybe someone can come on and advise you on how to check it to be sure.  You could always order it and if it's not the problem, send it back.  Here's your part in case you need it. Part number: AP3109394
Edited by Samurai Appliance Repair Man
1 person likes this
Thanks ill let you know if it works out.
Never mind I did not see that you had replaced the cold control. When you turn the control to off, does the refrigerator turn off? If it keeps running bad thermostat. I have seen this. Replace the thermostat.
Part number: ap3037004
grasshoppah stated the unit runs the compressor with the wires off the cold control, so its not the control
cant find the schematic for this kenmore, but the one thing i can think of that may still run the compressor with an open cold control is the adaptive defrost board
1 person likes this
