lrgenns1
Ca2762xyw0 whirlpool commercial linkage question
11 posts in this topic
This is a washer with missing linkage going from coin op slide to the timer inside the meter case. I found an older diagram that shows more parts inside the case than the current diagrams show, however it did not show any part numbers. There is an extension piece, and then the missing piece. I would guess it acts like a finger that dangles down and slides past the timer during coin insert, and catches timer on release as thats the direction the timer gets engaged. Any help would be greatly appreciated.
COIN SLIDE EXTENSION WASHER  part # Part number: 8316522
this is for the esd coin slide, forget if it works for verticle 8 and greenwald slides
lemme know slide type,if its not esd, and i'll see if i can figure out if that one works for the other slides
Edited by Samurai Appliance Repair Man
1 person likes this
checked the spacing on the slides i have around,they all appear the same,so this should work for any slide
I appreciate the quick response. I see thats the extension. I have that. But it appears there should be a piece that goes from the extension to the "clutch". Thats the part im seeking. My only other thought is is my clutch broken/missing a piece? It looks very much like the diagram so i lean toward missing a piece of linkage.
Thanks again
here is a good pic of the linkage, it has an arm that drops down from the side with a nylon roller or glide on it, does your extention have this arm?
http://media.datatail.com/docs/manual/118310_en.pdf
same pdf shows the dryer extention, it does not have the drop down arm
Edited by BrntToast
this is what the complete clutch looks like  Part number: AP2906865
Ok. Clutch looks same as amazon pic. So, that leaves the extension. The one in there is the same as the dryer one, without the rollers. So it seems i am looking at someone elses failed attempt of repair.
Ill get the roller one ordered.
I really appreciate your help. Above and beyond!
Thankyou
~Andy
pls post back when its all solved
dont forget you can order that part directly from this sites parts link
1 person likes this
Not all coin-op washer slide extensions have the roller on the coin slide extension, some just have an "L" leg coming down from the extension instead of the roller that engages the timer cam in the same fashion as the roller.
How about taking some pictures of what you have and posting, that might be of some help to help you determine what is going on.
The roller linkage was the missing piece. Washer up and running. Thankyou for all your help. (Also decided to look at dryer linkage, found out the coin slides had been swapped) go figure
glad to have helped  :)
and good job
brnt
