Wild190
Whirlpool wtw57esvw0 washer nothing works but spin and drain
6 posts in this topic
Whirlpool wtw57esvw0 washer no sound when started no humming or any movement at all.
Will spin and drain.
Both water solenoids work when supplied 110VAC.
Lid switch checks ok.
hose to water lever pressure switch clear (no obstructions).
Replaced water level pressure switch Part number: W10177795
with Part number: W10292584
last week for same symptoms.
Water level pressure switch violet to white 120VAC, pink to White 0VAC (should be 120VAC?).
Water temp switch white with red to white 0VAC (should be 120VAC?).
What might have caused switch Part number: W10292584
to go bad again in a week? Edited by Samurai Appliance Repair Man
I don't know what caused it to go bad but if you ordered it from APP you could return it and get another one for only the cost of shipping.Part number: AP4501024
Does seem to be the problem
Doc
Edited by electro_doc
check the drain hose installation for siphoning issues, if these washers go into a "long fill" failure the switch faults out and stops the filling, unfortunately there is not way to reset the switch
I agree.  A siphoning washer will tear up an ATC switch.
I never knew that, good to know!  I'm adding that to my notes of things to check when changing an ATC switch.  Could save a call back.  Thanks mucho!
Doc
The drain hose empties into a utility sink 33 inches above the unfinished floor. Hose ends 8 inches above the bottom of the sink. I have not seen the water level in the sink get up to the bottom of the drain hose. We do have a lint trap attached to the drain hose but it is not clogged. Water should be able to easily get out of it. Is there any of this I need to change?
