I've done EVERTHING!beer storage unit warmish ge profile top freezer TGB22PABPRWW
refrigerator warm
2 replies to this topic
#1 glutton4punishment
glutton4punishment
  • 1 posts
  • Flavorite Brew:iced tea
Posted 06 May 2014 - 01:15 PM
Diagnosis: Freezer food frozen, fridge food kinda cool.
Background: 14 year old fridge, have replaced defrost heater thermostats, evap fan previously.
what I've done:
Tested and verified as good:
1. defrost heater thermostat (lets current pass at freezing, closes off current at room temp)
2. timer (rotates by itself, turns off compressor/evap fan/etc. for 30 min., then restarts fridge)
3. defrost heater (113 ohms)
4. damper (open).
5. clear air duct path from freezer to fridge.
6. Evap coils (have light, uniform frosting on them, from top to bottom)
7. Reversed freezer and fridge doors side (from right to left) b/c of sagging, slight sealing prob.  This fixed that. Doors are straight now and compartments seem to be sealed.
8. Cleaned condenser coils a month ago, still beautiful.
9. Evap fan works.
10. Condenser fan works.
11. Everything on the troubleshooting chart.
Temps in freezer, refrigerator compartments: (F) -7, 40. Outside temp. 80.  This is at full blast on the temp. control.  Tried it in the middle for a few days, everything was warmer.  Normally it's 90F outside (and inside).  40+ temps aren't cold enough!
Puzzled by:
1.  defrost heater wouldn't come on.  I bypassed the thermostat.  Wouldn't heat up. Again, 113 ohms.
2.  defrost heater getting 18VAC.  No idea if this is normal.
Given the above two things, wouldn't you thinks that the evap coils would be a lump of ice??? They're not.  Again, not getting a lump of ice at the freon entrance as shown in the pic in the section on freon leak on this site.
OK, thanks a million, esp. to the samurai for his sense of humor!
#2 PDuff
PDuff
  • 2,112 posts
Posted 06 May 2014 - 02:14 PM
glutton, if possible post a picture of your evaporator frost pattern.  Should be getting 115 vac to the heater during defrost.  If unit is not defrosting properly, air flow can be affected and definitely evident in the frost pattern.  Other possibilities are a sticking or faulty damper (part discontinued) or other type air flow restriction.
When the cold control was set to halfway, what was the freezer temperature?
Also post correct model and serial number if possible.  This unit may be older than suspected, and there were some GE compressor issues in the late '80's/early '90's.
#3 BrntToast
BrntToast
    fellow,academy of sublime masters of appliantology
  • 1,307 posts
  • Flavorite Brew:i quit drinking the day i woke up nude on the hood of my car with my keys up my butt
Posted 06 May 2014 - 02:15 PM
did your cooling problem happen after the evap fan was changed?
maybe you used the wrong motor and its turning backwards
defrost heater should heat with def therm bypassed, power to the heater should be 120 volts AC
The only stupid question is the one not asked
hope i've been helpfull, if you wish to buy Brnt beer kick here
http://brnttoast.googlepages.com/home
feel free to prvt msg frigidaire questions my way
(i dont log in every day)
