Maytag Gas Dryer
#21
Posted 27 May 2005 - 08:01 PM
#22
Posted 28 May 2005 - 06:25 AM
Jwhansen
#23
Posted 28 May 2005 - 06:52 AM
Read More If we helped you kick some appliance bootay and saved you some coin, consider helping' us keep the lights on ==> http://beer.fixitnow.com
#24
Posted 31 May 2005 - 06:30 AM
Jwhansen
#25
Posted 31 May 2005 - 11:09 AM
#26
Posted 31 May 2005 - 11:52 AM
Jwhansen
#27
Posted 31 May 2005 - 12:09 PM
#28
Posted 01 June 2005 - 02:36 AM
No Way, I didn't think you ever slept. What kind of creamer do you put in that coffee?:snooze: Till Friday!!!
#29
Posted 01 June 2005 - 05:45 AM
#30
Posted 03 June 2005 - 03:09 AM
Jwhansen
#31
Posted 03 June 2005 - 06:09 AM
#32
Posted 03 June 2005 - 06:16 AM
Jwhansen
#33
Posted 03 June 2005 - 06:28 AM
#34
Posted 03 June 2005 - 06:32 AM
Jwhansen
#35
Posted 04 June 2005 - 12:55 AM
It sure sounds like the dryer is short cycling on the hi-limit safety t-stat on top of the burner cone which would indicate bad airflow.
Check the front and rear drum seals, blower wheel, and seal between front lint trap area and the blower housing. If any of these seals are bad air can not flow correctly and you will have the problem your experiencing.
As a tempory way to check this, bypass the hi-limit safety t-stat on top of the burner cone and run the dryer and see if it still shuts down to soon, DO NOT RUN LONGER THAN 10 MINUTES WITH THE HI-LIMIT SAFETY BYPASSED.
Eureka, CA 95501
