Whirlpool oven no bake or broil
4 replies to this topic
#1 Tutt
Tutt
  • 3 posts
Posted 10 May 2005 - 06:53 AM
Touchpad works, and acts like everything is ok. Fan kicks on, warm up counter starts. No codes flashing.  I checked the second breaker on the box, outside....on.
How do I pull codes?  Anybody run into this before?
Thanks.
#2 Pegi
Pegi
  • 13,120 posts
Posted 10 May 2005 - 08:43 AM
Model number.....:bathead:
#3 Tutt
Tutt
  • 3 posts
Posted 10 May 2005 - 09:14 AM
Sorry.....just a grasshopper.:?
Whirlpool  Model# RBS275PD86  Serial# X32401062
#4 Pegi
Pegi
  • 13,120 posts
Posted 10 May 2005 - 10:19 AM
Recheck the model number, the 86 will not be correct, might be  B6?  Here is a tech sheet to one close but may not be the one to yours.  But I see you did not tell us what your problem might be either????
http://www.servicema...t - 4451884.pdf
#5 Tutt
Tutt
  • 3 posts
Posted 11 May 2005 - 01:16 PM
It looks like the temp sensor is bad. It tested ok, but I pulled code indicating it, and I think the connection is bad.
It's either the sensor, or bad wiring. I'm gonna replace the sensor, and go from there.
