Maytag Washer Mystery Sound
6 replies to this topic
#1 JCrest01
JCrest01
    Ikkō-ikki
  • 41 posts
  • Flavorite Brew:Wawa Coffee
Posted 29 May 2014 - 09:18 AM
I'm working on a Maytag Washer MVWC200XW2.  When it agitates, its making a metallic sound.  Any ideas?  I was thinking motor or transmission, but as both of those are pretty pricey, I would rather not guess.
Thanks!
John
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,925 posts
  • Flavorite Brew:Killians Red
Posted 29 May 2014 - 09:47 AM
A video or audio recording would help.
#3 electro_doc
electro_doc
  • 1,018 posts
  • Flavorite Brew:orange juice
Posted 29 May 2014 - 10:35 AM
check the pump.  it's noted for the bearing coming loose and rubbing on the pulley.  I'd take a close look at that.
Doc
#4 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,925 posts
Posted 29 May 2014 - 10:39 AM
This is a VMW platform washer, Doc...no pulley on the drain pump on this one.
#5 PDuff
PDuff
  • 2,091 posts
Posted 29 May 2014 - 01:32 PM
Any noise during spin?  How do the suspensions rods and bearings look?
    Shōgun
  • Master Samurai Tech
  • 30,713 posts
Posted 29 May 2014 - 03:45 PM
Tilt it back and check that pulley bolt.
If that's good, then put it into diagnostic mode and get the error codes.  This video will help you to gird up your loins like a man:
#7 nickfixit
nickfixit
  • 2,200 posts
  • Flavorite Brew:Glen Livit
Posted 30 May 2014 - 05:03 AM
Look to see if spin basket has become loose from it's mount. You'll have to take off the agitator, one 7/16" screw is all that holds it on.
