Imperial 60" Gas Range Model IR-6-24
computepulse
computepulse
I have an Imperial Gas Range IR-6-24 in which the left side oven burner does not seem to be getting a strong enough flow of gas because the gas lights and just spirals around the burner.  Pilot seems fine.  I have never worked on this unit before so I am asking for someone who has experience on this model.
Thanks in advance
  • Replies 4
  • computepulse
  • computerpulse
  • tommytech
computepulse
Sorry it's a IR-6-G24 Imperial commercial oven
did you check gas pressure? gas volume? is the orifice sized correctly or correct size? does it have an air shutter,and is it adjusted correctly?
